Help with JDM B16 swap and MAP sensor
Old Jun 23, 2006 | 10:51 PM
Brian Hinson's Avatar
Default Help with JDM B16 swap and MAP sensor
Some friends and I just swapped a JDM B16 into a buddies car. His TB has no Map sensor, but at the same time, his swap didnt come with a firewall MAP, and the wire harness on the JDM motor has no plug for the MAP?
Should we use the usdm wire harness? Were kinda lost this is our first swap.
Thanks alot!
*oh yea, his car is a 94 DX*
Old Jun 24, 2006 | 12:13 AM
Default Re: Help with JDM B16 swap and MAP sensor (Brian Hinson)
Bump... I know some1 knows whatsup
Old Jun 24, 2006 | 12:54 AM
plz turn off trial user's Avatar
maybe cuh u dunt need a map in a b16a?
Old Jun 24, 2006 | 01:08 AM
strictly.business's Avatar
Banned
if the last motor had one, buy a map sensor for the b16, plug it in, run a hose from the nipple above the throttle body to the map sensor, zip tie the map sensor where it cant be seen. or wherever.
Old Jun 24, 2006 | 02:59 AM
JdmLub's Avatar
Default Re: (strictly.business)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business &raquo;</TD></TR><TR><TD CLASS="quote">if the last motor had one, buy a map sensor for the b16, plug it in, run a hose from the nipple above the throttle body to the map sensor, zip tie the map sensor where it cant be seen. or wherever.
pretty much what i did
Old Jun 24, 2006 | 03:20 AM
VRD^sam's Avatar
wat he said
Old Jun 24, 2006 | 04:38 AM
JSPECSIR's Avatar
Default Re: (..::ferio::..)
whered the map off the moter that came out go to just use it. ^^^^^ like they said
Old Jun 24, 2006 | 07:04 AM
tatmark1's Avatar
i have 2 firewall mounted maps
Old Jun 24, 2006 | 07:12 AM
spoonracer84eg's Avatar
Default Re: (tatmark1)
I used a d15 map sensor lol. What I was told is that the map sensors on JDM cars are mounted on the fire wall. So you dont get it with the swap. I used my d16 engine harness and plugged the map sensor into it.
Old Jun 24, 2006 | 07:18 AM
CRXified's Avatar
my b16 had a firewall MAP, but when i swapped it into my 92 Si hatch, it had the map right on the TB. i swapped the motor out then put the MAP on the firewall that came with the B16, but low and behold, i had no MAP plug because i used a CX harness with no MAP plug on the engine harness.
i had a spare plug for the MAP and just pinned the wires into the pasenger shock tower plug it's the 14plug at the passenger strut tower.
map plug colors are.
yel/red, wht, grn/wht.
the 14plug colors and locations are.
yel/grn pin5 = ecu location d19
pnk/wht pin6 = ecu location d17
grn/blu pin pin7 = ecu location d21.
heres a link to my post i made some time ago on it
https://honda-tech.com/zerothread?id=1468217&page=1
Old Jun 24, 2006 | 07:22 AM
axtran's Avatar
I have a '92 DX and i did exactly what CRXified did - cept I had the MAP wiring from the firewall and it worked fine.
Old Jun 24, 2006 | 08:14 AM
Default Re: (axtran)
yeah but his harness doesnt have a plug for the map.
Old Jun 24, 2006 | 01:20 PM
CRXified's Avatar
then hit up a junk yard and get 1, wire it in, luckily i had a spare harness with a MAP plug
Old Jun 24, 2006 | 04:05 PM
awesome, thanks for the help guys
bodiez
Oct 26, 2010 02:17 PM
jw15u
Nov 14, 2009 06:57 PM
dc2doi
Nov 9, 2007 12:16 PM
tallblondkid
Jul 19, 2004 10:22 AM
Yellow Dragon
Jul 23, 2003 02:01 PM
