low oil pressure @ idle?0psi?
Old Jun 23, 2006 | 10:42 PM
importdude2000's Avatar
Default low oil pressure @ idle?0psi?
after it warms up
sometimes its 5...then sometimes ZERO
if its really ZERO wouldnt the stock sender flash a oil light?
oil levels are good
i read while searching that
if you T off the line going to the turbo it will show<10psi
here is my setup
i hope its readable
Modified by importdude2000 at 1:25 AM 6/24/2006
Old Jun 23, 2006 | 11:32 PM
EK k kay's Avatar
Default Re: low oil pressure @ idle?0psi? (importdude2000)
I have mine setup the same was as yours using the Stealthmode oil line and firewall kit, but I currently don't have the turbo line hooked up because I don't have my turbo on yet. I don't have any similar problems like yours where it goes to zero.
Old Jun 23, 2006 | 11:53 PM
yah i dunno too
weird ****
i hope its my guage?
Old Jun 24, 2006 | 01:41 AM
TURBODC4TEG's Avatar
Default Re: (importdude2000)
let me ask u this if you cut off your car does your gauge need go below 0? if it does it should be the gauge. if it doesn't and it lines up right. then my friend it should be the oil pressure sending unit, been through 3 oil pressures. autometer will fix it send it to them hope that helps
Old Jun 24, 2006 | 03:01 AM
doc's Avatar
doc
I've my setup excatly like yours. It works well. With running engine i never see 0 pressure.
It looks like the sender unit or gauge is broke. i've seen this very often, even on brand new units.
Old Jun 24, 2006 | 03:46 AM
crazi-85crx's Avatar
it could even be just a bad ground. consider re-checking your wiring.
Old Jun 24, 2006 | 04:31 AM
Default Re: (crazi-85crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazi-85crx &raquo;</TD></TR><TR><TD CLASS="quote">it could even be just a bad ground. consider re-checking your wiring.</TD></TR></TABLE>
ill check on it in the morning
i hope its just the guage!
Old Jun 24, 2006 | 07:24 AM
shortyz21's Avatar
tee'ing off the turbo line wont effect readings....
Old Jun 24, 2006 | 08:47 AM
M.A.R.C.'s Avatar
Default Re: (shortyz21)
i have mine setup similarly but don't have those problems. what gauge is it?
Old Jun 24, 2006 | 10:30 AM
Default Re: (M.A.R.C.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M.A.R.C. &raquo;</TD></TR><TR><TD CLASS="quote">i have mine setup similarly but don't have those problems. what gauge is it?</TD></TR></TABLE>
meagn racing
i swore i always saw 10psi at idle
i hope its the guage!
Old Jun 24, 2006 | 10:58 AM
96 GSR-T's Avatar
Mine is tee'd off the block fitting and I see 30lb (2 bar ish) at idle and about 85 driving around (6+ bar)
Old Jun 24, 2006 | 03:51 PM
guage wireing looks fine
now
awaiting another oil pressure guage
changing oil/filter
if that doesnt go well
change the screen
and if that doenst fit it
i think my oilpump might be shot!
Old Jul 6, 2006 | 12:27 PM
JDMB20TDA's Avatar
im getting a zero oil pressure as well.
I cleaned out my oil line restrictor, changed to oem filter, and redid all my oil lines with honda-bond (removed shitty teflon tape)...
messed with it again today still zero, bringit off idle (@ about 1.5k rpm its @ 25 oil psi...)
I have switched from my super duper cool blox gauge to some shitty mechanical gauge and still fuckr'd up.
stupid ******' b20, only 40k miles
o well tell me how everything goes.
Old Jul 6, 2006 | 01:29 PM
Blown99civicsi's Avatar
A heathly motor should read around 10PSI for every 1000rpm's. So at 1000 rpm's oil pressure should read AT LEAST 10psi, most honda motors that have good rings and minimul leakdown(blowbye) read about 20PSI at idle 800-1000RPM's
Old Jul 6, 2006 | 01:40 PM
shortyz21's Avatar
Default Re: (Blown99civicsi)
depends how hot it is outside and how hot your cars running also..
also the kind of oil you use effects this to..
Old Jul 6, 2006 | 02:44 PM
ops i forgot to post what happend
it was
the guage
radio on-0psi
radio off 10psi
its the ground/power system with the sender unit
Old Jul 6, 2006 | 03:44 PM
shortyz21's Avatar
electronic gauges.. i dont like em
Old Jul 6, 2006 | 04:09 PM
JDMB20TDA's Avatar
damnit you had an easy fix. im rocking the mechanical gauge w/same results
hotshot100
Apr 14, 2010 05:10 PM
cantaffordaccord
Feb 21, 2010 09:52 PM
BlueShadow
Apr 11, 2005 01:17 PM
W O T
Jan 29, 2005 08:01 PM
AzG35
Nov 15, 2004 09:08 PM
