Help ek with JDM H22
Old Jun 23, 2006 | 03:46 PM
peregine's Avatar
Default Help ek with JDM H22
So i got a 98 EK with a JDM H22 a few days. One my way home with it, it threw the check engine light so i cut it off turned it back on and it was fine for awhile. then the next night i was drivng it came on again so i did the same and it turned off but now it keeps coming on and vtec will not engage. So i used the jumper and it is showing a code 12, which is EGR i believe. So then i looked at the EGR and the top hose coming off of it was not hooked up. I don't know where it needs to go and i am not sure why that would cut off VTEC. I was told that the O2 sensor might be the problem but will that cut out the VTEC. I have checked the selinoid and it plugged it.
So any help will be nice.
Thanks
Jimmy
Old Jun 23, 2006 | 05:34 PM
prelude1897's Avatar
Default Re: Help ek with JDM H22 (peregine)
could you take a pic to show us where the hose is disconnected at? That'll defenitly help us out so we can tell you where to place it
Old Jun 23, 2006 | 10:34 PM
peregine's Avatar
Default Re: Help ek with JDM H22 (prelude1897)
sure i will put it up tomorrow
Old Jun 24, 2006 | 02:03 PM
peregine's Avatar
So it turns out not to be a code 12 it is a code 22 which is vtec oil pressure right? So i was told to take the selinoid off and spray with cleaner what do yall think?
Old Jun 24, 2006 | 03:13 PM
PrecisionH23a's Avatar
Check the selenoid out and make sure there's no junk in the screen. Make sure all the wires are ran properly also.
Is your wiring harness from a vtec or non-vtec model?
Old Jun 24, 2006 | 10:33 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: Help ek with JDM H22 (PrecisionH23a)
when the last time you checked your oil????? or changed it?? do what anthony said...and change your oil.......all I can think of right now......and for future referance when yo uthrow a CEL yor ECU goes into limp mode and your redline drops to 6000 rpms you run rich as hell and vtec goes bye bye......
poisonousbeef
Nov 3, 2007 01:21 PM
blacktsi
Oct 10, 2006 07:25 PM
mdj_ge
Aug 22, 2004 11:02 PM
HRDCORD
Jun 21, 2004 10:23 PM
KENLUDE97
Jan 13, 2003 04:28 AM
