uberdata for jdm p30 ecu???
i was thinking of running either the p06 or p28 and get it chipped. my current ecu keeps throwing a code for oxygen sensor, but when i tried my friends p28 running a type r program, ran so much better, but rich and NO CELs.
the ecu you run doesnt matter as long as its the correct odb. personally i would be using crome on obd1 if i were you, uberdata stinks. but yeah, your friends ecu probably didnt throw a code because closed loop is disabled. just get your chipped and either fix the o2 problem, or run open loop.
stackedhouse
May 17, 2012 05:37 PM
ninji
Nov 3, 2004 12:21 PM
