ITR steering rack fitting sizes
found that the smaller fitting is the same size as the oil pan drain bolt 14mmX1.5, but not sure what the other one is. Its slightly bigger.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_gs-r »</TD></TR><TR><TD CLASS="quote">good luck getting it loose i tried for two hours then i gave up and cut the hard line and flared it and put some hose on it and called it a day.</TD></TR></TABLE>
Were you using a flare nut wrench? Usually when it's really difficult to remove something, that means you're using the wrong tools. I've done my share of that in the past.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid »</TD></TR><TR><TD CLASS="quote">
I couldn't of said that better myself.
</TD></TR></TABLE>I couldn't of said that better myself.
my rack has been open for about 3 years. getting tired of what little l00b there is in the rack squirting out all over the motor, not to mention the ungodly amounts of **** that has gotten in there.
I'm hoping this is the same for an Em1, which I'm thinking it is. I've been searching for the size for hrs, trying to find a fitting to loop my system.
