Hiding ECU?
Does anyone know if a P28 ecu will fit in the same area as the P2T Ecu? Just by looking I don't think it will... Correct me if I am wrong. And if it doesn't anyone have any suggestions as to where to hide it?
Ecu's are the same size. The USDM ecu's are the bigger out of the bunch being rectangular shaped. The USDM cars are designed to "tuck" the ECU"s behind a kick panel. JDM ECU"s are a little shorter being square, so I feel theese would be just as easy to tuck behind the kick panel.
You were wrong, so I corrected you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">My p28 was significantly larger then my p2t, then adding the conversion harness didnt help. But it will work you just have to keep trying and you will find a way.</TD></TR></TABLE>
Thanks... Yeah mine seems a decent bit larger.
just put it in the same spot and fabricate a bracket (only need a thin piece of metal) and drill out some holes and u can use the old holes that were there :-\
big_dong861
Nov 5, 2007 05:49 AM
