H22A fuel injector issues
Old Jun 23, 2006 | 01:48 AM
nblanton's Avatar
Default H22A fuel injector issues
I just got a '92 CX with an H22A4 in it. It was pretty poorly setup and I'm fixing the issues with the car now. I've picked up a P13 ecu, a H22A1 OBD1 complete harness, and some better mounts. The question is, I know that the OBD1 'lude came with low-impedance injectors and I plan on switching either to the 345cc injectors that were supposed to be in an OBD1 H22 or some 360cc DSM's. (Mainly because they are a lot cheaper) So, do I still need a resistor box to run the low impedance injectors, or with the ECU work with them with out it?
Old Jun 23, 2006 | 04:21 AM
veganej's Avatar
Default Re: H22A fuel injector issues (nblanton)
yes you still need the resistor box
Old Jun 23, 2006 | 05:59 AM
Built2.0Lude's Avatar
Since you are obviously switching everything to obd1, do you know that you will have to get a obd1 distributor?
surkitroller
Dec 29, 2009 12:58 PM
spraymysol
Dec 8, 2008 02:48 PM
rogue3221
Nov 23, 2004 11:36 AM
EGHatchy
Jun 16, 2002 07:40 AM
