need help? obd0-obd1 converting d16z6 swap
Old Jun 22, 2006 | 11:35 PM
projectef's Avatar
Default need help? obd0-obd1 converting d16z6 swap
i have a 90 civic si, and im putting a d16z6 swap into it. i no my stock a6 distributor wont fit on the z6 head, so do i use the z6 distrib...? and what about the distributor plugs, how do i go bout that?
Old Jun 23, 2006 | 02:24 AM
court's Avatar
25 Year Member
Default Re: need help? obd0-obd1 converting d16z6 swap (projectef)
if you are going to run on obd1 ecu, you need an obd1 dizz
Old Jun 23, 2006 | 05:41 AM
pinecone's Avatar
Default Re: need help? obd0-obd1 converting d16z6 swap (court)
You will need a dizzy adapter:
Old Jun 23, 2006 | 05:53 AM
junior40er's Avatar
Default Re: need help? obd0-obd1 converting d16z6 swap (pinecone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinecone &raquo;</TD></TR><TR><TD CLASS="quote">You will need a dizzy adapter:
</TD></TR></TABLE>can u order that or can we make it. if so how do we do it? Also will obd-0 plug into Z6 minifolds sensors and emmision hoses?
Old Jun 23, 2006 | 06:08 AM
pinecone's Avatar
Default Re: need help? obd0-obd1 converting d16z6 swap (junior40er)
You can make it. All you need are the plugs off an OBD0 dizzy and the plugs that go into the z6 dizzy plugs from the engine harness. The wiring diagrams are on here.
Yes the rest of the OBD0 plugs will plug in. Atleast to the best of my knowledge.
Old Jun 23, 2006 | 08:09 AM
4thgenhtch's Avatar
yes sir you are correct
Old Jun 23, 2006 | 08:34 AM
pinecone's Avatar
Default Re: need help? obd0-obd1 converting d16z6 swap (4thgenhtch)
Even more help, here is the thread discussing the dizzy pinouts.
https://honda-tech.com/zerothread?id=1349052
Old Jun 23, 2006 | 04:00 PM
projectef's Avatar
thanks man, i just ordered that adapter. do i need 2 convert any other thing, like in the engine bay? that lil silver box on the right side of the eng.. bay?
Old Jun 23, 2006 | 05:40 PM
pinecone's Avatar
Nope keep it and keep using OBD0 injectors. It will work fine.
Do you have the OBD0-Obd1 conversion harnesses and subharnesses?
Old Jun 24, 2006 | 09:36 PM
91SiZ6's Avatar
For a California legal OBD swap, you have to use OBDI injectors and remove the resistor box.
What you need.
P28 ECU (chipped ECU from J-K-Tuning.com for $160...just make sure it's a P28 and not a P06, the Ref might check)
OBD0 -&gt; OBDI conversion harness ($104 shipped from RyWire.com)
4-wire O2 sensor ($82 shipped from RyWire.com)
Distributor adaptors ($25 shipped from RyWire.com)
OBDI injectors (should already be in the Z6 IM)
Grey injector plugs (got mine from a scrap Z6 harness, check with RyWire.)
Injector block off (optional, just looks better than soldering everything together...from the scrap harness)
VTEC/O2 subharness (made my own from the scrap Z6 harness)
OBDI MPFI distributor (bought a reman. from eBay for $145 shipped with new cap, coil, and rotor)
I'm pretty sure that's everything.
PiXeL
Sep 19, 2006 05:16 PM
Jamez
Apr 16, 2005 07:59 AM
iNetForce
Jul 12, 2004 12:26 PM
EARLdaSQUIRREL
May 20, 2003 11:15 AM
