A lot of blowby.. high oil pressure at the turbo??
Old Jun 22, 2006 | 11:08 PM
watsvtecEK's Avatar
Default A lot of blowby.. high oil pressure at the turbo??
I messed up my motor real bad about 2 weeks ago. i did a compression test and one cylinder was 60 and another was 120 and the other two were 185. well my question is that my turbo was smoking alot so i decided to rebuild it. after i rebuilt it i bolted it up and it was still smoking like a chimney. then today i got a used t3/t4 that was in good condition no shaft play and was clean and it had no sines of blown seals. so i bolted this up and started it and even more smoke!! so im guessing with major blow-by i am getting is giving WAY to much oil pressure at the turbo and it is just getting past the seals. Could this be true or do i just have realy bad luck? i am going to try an oil restrictor tomorrow, but the reason i am driving it is because i need to get back and forth to work to get a new motor..
Old Jun 22, 2006 | 11:52 PM
komat's Avatar
Default Re: A lot of blowby.. high oil pressure at the turbo?? (D 2da A9)
ringland cracked
Old Jun 23, 2006 | 04:24 AM
SOHC_MShue's Avatar
or maybe its just smoking because your motor is blown....
Old Jun 23, 2006 | 05:08 AM
eddie_ek's Avatar
ringlands are brocken turbo maybe ok
Old Jun 23, 2006 | 07:31 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D 2da A9 &raquo;</TD></TR><TR><TD CLASS="quote">I messed up my motor real bad about 2 weeks ago. i did a compression test and one cylinder was 60 and another was 120 and the other two were 185. well my question is that my turbo was smoking alot so i decided to rebuild it.</TD></TR></TABLE>
your motor is at ~30% compression in one cylinder. a new turbo is not going to help with your blowby. LOL
Old Jun 23, 2006 | 09:29 AM
watsvtecEK's Avatar
Default Re: A lot of blowby.. high oil pressure at the turbo?? (notoriousB)
i did not make it clear. my question was with all the blowby i am getting will that make my oil pressure high enough to make my turbo burn oil?? yes i know i have cracked ringlands but i have to drive my car for a few more weeks to get to work. and no the smoke is coming from the turbo because i started it up open mani and there was no smoke, and the plugs are dry.
Old Jun 23, 2006 | 11:10 PM
watsvtecEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D 2da A9 &raquo;</TD></TR><TR><TD CLASS="quote">i did not make it clear. my question was with all the blowby i am getting will that make my oil pressure high enough to make my turbo burn oil?? .</TD></TR></TABLE>
Old Jun 24, 2006 | 02:42 AM
jeremydde's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D 2da A9 &raquo;</TD></TR><TR><TD CLASS="quote">i did not make it clear. my question was with all the blowby i am getting will that make my oil pressure high enough to make my turbo burn oil?? yes i know i have cracked ringlands but i have to drive my car for a few more weeks to get to work. and no the smoke is coming from the turbo because i started it up open mani and there was no smoke, and the plugs are dry.</TD></TR></TABLE>
Yes, excessive crankcase pressure (blowby) can prevent the turbo return line from emptying quick enough and the oil can back up in the turbo and leak/smoke.
Old Jun 24, 2006 | 07:08 AM
TurboCoop's Avatar
Default Re: A lot of blowby.. high oil pressure at the turbo?? (jeremydde)
I know exactly how you feel. not having a daily driver sucks ***, I had the same thing happen to me. Dont get a restrictor, just try to fix the ringlands soon and deal with the smoke for a while. I hope the cops where you are arent ******** about it. I got pulled over cause my car was smoking like a bitch once. Sorry my post didnt really help you that much at all, I need to go back to sleep
PINKS
Aug 3, 2006 12:32 PM
steve96accord
Jun 30, 2006 09:40 PM
komat
May 13, 2006 02:04 PM
Johnny_Rocket
May 6, 2005 09:26 PM
