Brake Master Cylinder Question
Old Jun 22, 2006 | 08:26 PM
fongph's Avatar
* B A N N E D *
Default Brake Master Cylinder Question
Recently I had a sponge-feeling,keep-sinking brake pedal after a complete stop so I think the Brake Master Cylinder is going and started looking for one. Upon researching on the Master Cylinder sizes thread https://honda-tech.com/zerothread?id=928201. My car is a 93 Civic 4dr EX w/ABS and what the size thread is saying agreed to what I found online.
1"
46100-SR3-833
- 92-95 Civic EX ABS (4-DR)
- 94-95 Civic EX ABS (2-DR)
- 94 Civic Si ABS (3-DR)
- 94-95 Civic LX ABS (4-DR)
- 95-97 del Sol ABS
I decided to check out the condition of my current brake master cylinder before ordering one which costs around $200 . Giving me a stunt, I found out that my current brake master cylinder is a 15/16.
1) How can a 15/16 brake master cylinder fit into the place where a 1" supposes to sit?
2) My ABS light stayed on the first day I got the cars two years ago. Could my current brake master cylinder actually be a non-ABS and causing the light to come on because of malfunctioning?
3) Can some of you guys help me to check your brake master cylinder if your car is sharing the same brake master cylinder as listed above? I just want to verify if it is indeed a 1" ...
4) How can I find out if it is a ABS master cylinder or not?
Thank you very much
Old Jun 22, 2006 | 08:34 PM
SOHC4life 96's Avatar
Default Re: Brake Master Cylinder Question (fongph)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fongph &raquo;</TD></TR><TR><TD CLASS="quote">
1) How can a 15/16 brake master cylinder fit into the place where a 1" supposes to sit?</TD></TR></TABLE>
The size of the master cylinder doesnt matter. As long as the two bolts line up, you can fit any master cylinder on any brake booster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by &raquo;</TD></TR><TR><TD CLASS="quote">
2) My ABS light stayed on the first day I got the cars two years ago. Could my current brake master cylinder actually be a non-ABS and causing the light to come on because of malfunctioning?</TD></TR></TABLE>
Most likely not.
3) Can some of you guys help me to check your brake master cylinder if your car is sharing the same brake master cylinder as listed above? I just want to verify if it is indeed a 1" ...</TD></TR></TABLE>
Don't have that car, so I'm no help here.
4) How can I find out if it is a ABS master cylinder or not?</TD></TR></TABLE>
I don't think it matters. Though I'm not sure.
Old Jun 26, 2006 | 12:05 AM
fongph's Avatar
* B A N N E D *
Default Re: Brake Master Cylinder Question (SOHC4life 96)
If I found no leak, can the brake master cylinder still be bad? How do I test if it is bad?
Thanks
Old Jun 26, 2006 | 11:26 AM
fongph's Avatar
* B A N N E D *
bump... need an answer please
Old Jun 28, 2006 | 09:16 PM
fongph's Avatar
* B A N N E D *
Thanks
Thanks
fongph
Jun 16, 2006 06:05 PM
Ballade
Jul 3, 2004 06:46 PM
ares650
26
Feb 19, 2004 10:08 PM
moridin2004
20
Dec 4, 2003 10:19 PM
DMF
15
Feb 1, 2003 04:02 PM
