what is this?
Old Jun 22, 2006 | 08:20 PM
paranoiattack91's Avatar
Default what is this?
I drive an 92 eg and i took a run down the mountain tonight. anytime i come braking hard into a corner i feel/hear a vibration coming from what feels like the left front wheel. Help?
Old Jun 22, 2006 | 08:25 PM
Master23's Avatar
Default Re: what is this? (paranoiattack91)
Check your tires for bumps or change your pads and rotors for new ones.
Old Jun 22, 2006 | 08:27 PM
Default Re: what is this? (Master23)
the tires are brand new (literally) just put them on yesterday. and as for the brakes they are fine when braking hard straight, its only when cornering.
Old Jun 22, 2006 | 08:28 PM
jdeemseerx's Avatar
when you put the tires on did you have them balanced also?
Old Jun 22, 2006 | 08:29 PM
CBEengineering's Avatar
wheel bearing or loose lugnuts
Old Jun 22, 2006 | 08:30 PM
the tires were balanced. and as for the wheel bearing why would it only do it while cornering and braking?
Old Jun 22, 2006 | 09:02 PM
Any other ideas guys?
Old Jun 22, 2006 | 10:51 PM
.Kevin.'s Avatar
Default Re: (paranoiattack91)
warped rotors
im willing to bet on it
Old Jun 22, 2006 | 11:39 PM
NY93CivicEx's Avatar
Default Re: (k20kev)
warped rotors
when your rotors heat up, if you slam your breaks the pads warp the rotors permenantly out of shape.. creating a bumpy stopping surface the next time you stop.. If they are expensive rotors (it shouldnt happen as easy) but you can have them resurfaced, if they are cheap then replace them.
Old Jun 23, 2006 | 02:36 AM
Default Re: (NY93CivicEx)
that my buddy was saying. its an si so it has 4 wheel discs. should i just get new stock rotors?
Old Jun 23, 2006 | 04:46 AM
nota-eg's Avatar
You could also take them to have them turned. I think it's around $10/rotor to have them turned.
If you decide to do that take a fine piece of sandpaper and just go in a swirling motion around the rotor once you get them back. That'll put a non-directoinal finish on the rotors, which will keep them from squealing.
Old Jun 23, 2006 | 09:13 AM
jacka$$'s Avatar
Default Re: (nota-eg)
Ya what they said.
ezol
Jul 24, 2007 02:41 PM
Baron55
Jul 20, 2006 08:31 AM
lumi2
Jun 19, 2005 03:29 PM
wAnNaBe4VTEC
Nov 6, 2004 02:16 PM
devilpuppy
Jul 21, 2004 08:01 PM
