Wiseco Rings for 84mm Endyn 9:1 Pistons?
In the process of peicing my motor back together.
I have an 84mm b18b1 bare block, an LS crank, LS eagle Rods, and 84mm Endyn Rollerwave 9:1 comp pistons.
I need to purchase new pistons rings, rod bearings and main bearings to finish up the motor.
The problem is I bought all the parts used awhile back and I dont have, and have no way of getting, a part number on the pistons, and Im wondering if anyone (if its possible to determine with the little info. I have) knows a Part Number for which ring set to run with those pistons.
Also what main and rod bearings would you guys recomend?
Thanks HT
Thanks HT
ITR.#1446
Jul 22, 2008 09:34 PM
