Car just plain won't start
Old Jun 22, 2006 | 05:33 PM
dennis278's Avatar
Default Car just plain won't start
My car will not turn over, in fact its like the engine is not evan communicating with the rest of the car. When you turn the key to the on postition, the according lights don't evan light up on the dash ( oil pressure, check engine...) i tried a different main relay, a different ecu, checked the fuses and the battery has power. I have a track day on sunday so any help would be much appreciated.
Old Jun 22, 2006 | 06:43 PM
dennis278's Avatar
Old Jun 22, 2006 | 06:48 PM
Slamaccord's Avatar
Default Re: (dennis278)
Did you check your main fuse ?
Old Jun 22, 2006 | 06:56 PM
dennis278's Avatar
Main fuse? do you mean the main relay?
Old Jun 22, 2006 | 08:38 PM
jdeemseerx's Avatar
the main fuse is in your fusebox under the hood.. the battery fuse see if it has power on both sides of it with a test light.. have you done anything to the car lately, or did it just not start out of nowhere?
Old Jun 23, 2006 | 05:06 AM
dennis278's Avatar
i had just changed the clutch, oil and spark plugs, but it drove fine after that, then later that night i went to start it and i could hear a faint clicking noise and the speedo jumped up like when you start a motorcycle. I push started it thinking it was a low battery and then the next morning at home it did the same thing. I tried boosting it but it didn't change a thing, so i threw in a different starter and still nothing.
Old Jun 23, 2006 | 05:11 AM
dennis278's Avatar
forgot to mention, radio, lights, and fan all still work fine, its just the engine that is getting no power.
Old Jun 23, 2006 | 07:30 AM
dennis278's Avatar
the grounds are all good, electricity to the engine is either very faint and the warning lights on the dash light up slightly on occasion, other wise the engines power is completely dead. also all the fuses under the hood seem to be fine.
Old Jun 23, 2006 | 07:49 AM
the jdmchop's Avatar
bad ignition switch?
had one in my coupe that caused positive ground when i turned the key
Old Jun 23, 2006 | 07:15 PM
dennis278's Avatar
no dude its not that
Old Jun 23, 2006 | 08:45 PM
jdeemseerx's Avatar
maybe your alternator is no good? or ive seen the wire on the alternator come loose and give the same symptoms try wiggling it and see if its loose
FlewByU352
Sep 22, 2011 12:15 PM
TeamRiskEG6
29
Aug 7, 2008 05:53 AM
M2B4
Dec 19, 2006 07:33 AM
egcivic
Nov 20, 2006 05:32 PM
DIYMIKE
Jan 30, 2005 09:39 AM
