NEED HELP!!!: Removing aftermarket steering wheel****** Pics
Old Jun 22, 2006 | 04:21 PM
dohctor_B's Avatar
Default NEED HELP!!!: Removing aftermarket steering wheel****** Pics
I need some help with removing my aftermarket steering wheel. I need to know how to get this sliverish metal thing off. I tried pulling it off and i looked for some screws that might be holding it in place but nothing... here are some pics
Old Jun 22, 2006 | 04:26 PM
B16CivicEX's Avatar
may need to get a puller
Old Jun 22, 2006 | 04:34 PM
Otherguy's Avatar
NASIOC.com
Default Re: (AirForceB16)
Cut it off... lol jk... what i did with mine is just removed nut that holds the hub and put the steering wheel back on and just put some rope around it and pulled the ****** out... also wd-40 helps
Old Jun 22, 2006 | 04:44 PM
EeeJayEight's Avatar
Default Re: (Otherguy)
i used a bar and hit it off. bad idea... then the second time i did it.. i had a momo hub.. so it was different.. but i put a bar through the holes in it.. and yanked... almost smashed my head.. that was another bad idea.
just rent the tool at autozone
Old Jun 22, 2006 | 05:16 PM
delslowhonda's Avatar
like the one dude said, grab a gear puller. they come in handy all the time on different projects.
Old Jun 22, 2006 | 05:26 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: (delslowhonda)
After u take off the center nut, bolt the wheel back on it. Then pull with the steering wheel while a buddy taps the hub with a mallet
Old Jun 22, 2006 | 06:43 PM
dohctor_B's Avatar
Default Re: (rukawa1one)
thanx guys, great advice, i might try the puller if i get a chance or one of the other more ghetto ways...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EeeJayEight &raquo;</TD></TR><TR><TD CLASS="quote">and yanked... almost smashed my head.. that was another bad idea.
except this one
Old Jun 22, 2006 | 06:45 PM
B7AudiA4's Avatar
Default Re: (EeeJayEight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EeeJayEight &raquo;</TD></TR><TR><TD CLASS="quote">i used a bar and hit it off. bad idea... then the second time i did it.. i had a momo hub.. so it was different.. but i put a bar through the holes in it.. and yanked... almost smashed my head.. that was another bad idea.
hahhahahaha, you made my day.
dohctor_B's Avatar
Default Re: (iSRT_Vtec)
Oh, i also need a cable reel/clock spring if anyone has one lying around
Old Jun 23, 2006 | 06:57 AM
B16CivicEX's Avatar
with cruise or with out
Old Jun 23, 2006 | 09:12 AM
jacka$$'s Avatar
Put the wheel back on and pull till it hurts. Thats when it will come loose and get you in the teeth.
Old Jun 23, 2006 | 01:14 PM
hatchi's Avatar
Default Re: (jacka$$)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacka$$ &raquo;</TD></TR><TR><TD CLASS="quote">Put the wheel back on and pull till it hurts. Thats when it will come loose and get you in the teeth. </TD></TR></TABLE>
this will work. Also wiggle it up down side side
b18_crx
Jun 19, 2006 09:19 AM
Sijray21
Feb 28, 2006 08:33 AM
ek_will
Dec 29, 2005 07:45 PM
GSRfoedoe
Feb 28, 2004 09:00 AM
