oil pressure gauges drops to zerop @ idle... after oil change?
I bought a brand new electronic oil pressure gauge recently and it was always acting up (reading a constant 25psi under idle/WOT, but just the other day I changed my oil and checked it for leaks and all is good. But after driving for about 10 min the oil presusre would drop to zero
Give it gas back to 25ish...??? i think im gunna send it back If no one has any ideas...
also is there anyway to check the resistance of the sending unit to judge oilpressure?
cause its @ about 220 ohms under idle (zero-5 psi) and 140ish under throttle (25-30 psi)
The motor has 40k on it sooo I HIGHLY doubt its a failure, but i may be wrong. Soo i f anyone could give me a hand or has any ideas for me Id be more than appreciative.
Modified by JDMB20TDA at 3:36 PM 6/23/2006
And this has what to do with appearance?
Anywho it sounds like you have wired it up wrong, re-check all your wires and use a multi-meter to determine which ones are 12v constant and 12v ignition, i'd imagine you have them mixed up.
thank you. I could not find a better suited catagory to post this is.
again thanks alot, and you wouldnt happen to kno what the signal wire should be reading @ idle.
what kind of oil filter are you using...
we had a teg come into the shop with a oil pressure problem and vtec wasn't enguaging... turned out to be a FRAM filter that was causing the problem.... i wouldn't recomend those... EVER!
I am using a fram but thats what I have always used...
Do u just recommend a factory honda filter?
but I do think it is a gauge problem bing like i said before the gauge was only reading 25psi under wot/idle... now it drops to zero
i dont understand this...
TeamSeanFTW
Mar 15, 2011 06:41 PM
AsSanitySlipsAway
12
Aug 27, 2006 09:55 AM
JDMB20TDA
Jun 29, 2006 10:13 PM
