another a/c question *EJ8 with swap* HELP!
Old Jun 22, 2006 | 02:00 PM
BSERIEuS's Avatar
Default another a/c question *EJ8 with swap* HELP!
will everything from a 99-00 SI fit into my car.
compressor
condenser
lines
bracket
i am running a GSR and do not have the lines/compressor/condensor from the swap.
**i do know that the d-series compressor will work with the del sol bracket....BUT...i was just wondering if i have everything completely off an EM1 SI...will it work just fine**
Old Jun 22, 2006 | 02:15 PM
B16b-EJ8's Avatar
I would also like to know this...
Old Jun 22, 2006 | 03:42 PM
B16CivicEX's Avatar
Default Re: (ProjectNoob)
what year and model is your car
Old Jun 22, 2006 | 04:34 PM
BSERIEuS's Avatar
96 civic EX
Old Jun 22, 2006 | 04:50 PM
Rock Meathammer's Avatar
Default Re: (BSERIEuS)
Yes. If you get the entire system from an EM1 it will work. Your civic chasis is identicle in the engine bay.
Old Jun 22, 2006 | 04:51 PM
Default Re: (B20 EJ6)
You may want to use the gsr bracket and compressor. I'm not too sure about the compatibility of the b16 bracket and the b18c bracket.
Old Jun 22, 2006 | 05:00 PM
BSERIEuS's Avatar
hmm...well...i do have the chance to buy the condensor and lines. and i do have a GSR compressor sittin around. so i guess the question is....
will a GSR compressor work if i have the lines and condensor from an SI *EM1*?
Old Jun 22, 2006 | 05:05 PM
lines to compressor?? Yes. EM1 lines to EJ8 evaporator?? Yes
Old Jun 23, 2006 | 11:30 AM
BSERIEuS's Avatar
ok....well the guy who i was buyin the stuff off of flaked. but thanks for the info!
quick question.....i have a local guy that is selling his a/c components out of his wrecked 96 civic 4 door. im sure that stuff will fit. i guess the new question is.
will the lines work with the condensor from a 99 SI? lines/compressor are from a 96 civic 4 door.
Old Jun 23, 2006 | 11:41 AM
mathieucivic's Avatar
The EM1 and GSR compressor is the same fit and function.
The standard civic (D series) is différent
The complete EM1 A/C system fit perfectly on your car.
or you can use the complete D series system with a delsol vtec compressor braket
Beacause the D and B series compressor and flexible hoses is différent
Old Jun 23, 2006 | 06:23 PM
BSERIEuS's Avatar
thanks a bunch.
finally gettin A/C in the ride!
Domani99
Sep 1, 2011 06:40 PM
kylefakesi-r
Jul 8, 2007 10:10 PM
stehigs321
10
May 8, 2004 01:49 PM
stehigs321
May 8, 2004 11:04 AM
stehigs321
Mar 25, 2004 09:38 AM
