Honda S2000 Honda S2000
Need Help!
Old Jun 22, 2006 | 12:05 PM
EJ8 GSR-T's Avatar
Default Need Help!
So i have a 2003 s2000, it was comptec supercharged and dynod to 333rhp. Now i melted a piston, and decided to get it rebuild with forged parts. The shop used cp 8.5 or 9:1 comp pistons, and eagle rods. Now they call me and tell me its done, and dynod at 200whp at 7 or 8 psi. Now this seems like **** to me becuase orginally at 6psi it made 333rwhp, so what do you s2000 guys think they could of fucked up? I know that going from around 11:1 to 8.5 or 9:1 makes a difference, but i feel its a bit rediculous.
Old Jun 22, 2006 | 12:10 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Need Help! (EJ8 GSR-T)
Compression has something to do with it. You'd need 8.5-9 CR when you're planning to run 20+ lbs of boost. With that 8lbs, 10:1 would still have been fine. Slap your motor builder.
Old Jun 22, 2006 | 01:04 PM
EJ8 GSR-T's Avatar
the deal is i stilll owe the shop about 3k....so what now?
Old Jun 22, 2006 | 01:08 PM
* B A N N E D *
New parts = more money.
Either follow through and go high boost, or sell that motor to a booster and start over.
Old Jun 22, 2006 | 02:13 PM
EJ8 GSR-T's Avatar
Default Re: Need Help! (FR-MOB: Projekt)
yeah but dont you think that even with lower compression. 200 hp is a bit low for 8psi?
Old Jun 22, 2006 | 03:04 PM
ArinX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">yeah but dont you think that even with lower compression. 200 hp is a bit low for 8psi?</TD></TR></TABLE>
8.5 is a very low compression. Up your boost to about 14- 16lbs at that compression.
Old Jun 22, 2006 | 04:33 PM
EJ8 GSR-T's Avatar
Default Re: Need Help! (ArinX)
prob. is that its a comptec supercharger, and i dont really know how high the boost will go without overstressing the charger
Old Jun 22, 2006 | 05:15 PM
revhi's Avatar
You can go up to 14, but your loosing effeciency. Youll need all new engine management, inj, fule pump, though.
333 sounds high, you must have been running very lean hence melted piston. Cut 30whp off that by running a safe a/f and 8.5:1 pistons, 200whp might be right.
Also each dynos different.
Old Jun 22, 2006 | 05:25 PM
EJ8 GSR-T's Avatar
Default Re: (revhi)
200whp! i mean that like stock numbers! the thing is, i have spent tons on it, new engine managmetn, larger injectors, new fuel pump everything, and 200whp is way shy of what it should be.
Old Jun 22, 2006 | 06:01 PM
revhi's Avatar
Go to a higher boost pulley, who told them to use such low compression pistons?
Old Jun 22, 2006 | 06:30 PM
Atheist's Avatar
Low comp pistons like that are fine really, you can usually work that out with cam timing anyway. Those numbers seem very low -- increase the boost!
Old Jun 22, 2006 | 06:38 PM
iam7head's Avatar
Default Re: (Atheist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist &raquo;</TD></TR><TR><TD CLASS="quote">Low comp pistons like that are fine really, you can usually work that out with cam timing anyway. Those numbers seem very low -- increase the boost!</TD></TR></TABLE>
what's the spec of the timing?
are you still running the fuel map from last set up?
Old Jun 22, 2006 | 07:18 PM
EJ8 GSR-T's Avatar
Default Re: (iam7head)
no last setup was on vafc...now its running greddy emanage ultimate. My feeling is they had no idea what they were doing on any of head headwork, timing included. They are the ones who figued those were the correct pistons to use. The prob is it allready has a pretty small pully in it, i dont know how much more i could get outa it
Bseriescivic5
Nov 24, 2006 12:26 PM
oilguzzler
Nov 17, 2005 07:52 PM
PGT Driver
Apr 24, 2004 10:51 AM
MaD3 In JaPaN
Honda S2000
48
May 6, 2002 06:51 PM
BLaCKWiDoWSi
Nov 2, 2001 03:12 PM
