Infinity Kappa 60.7cs or Polk Audio db6500
Old Jun 22, 2006 | 09:39 AM
Earthworm Jim's Avatar
Default Infinity Kappa 60.7cs or Polk Audio db6500
I need speakers for my EP3 and I'm not good with stereo equipment so please help a brother out
http://www.crutchfield.com/S-v...607CS
or
http://www.crutchfield.com/S-v...B6500
Thanks in advance. If there's anything better please post the site
Old Jun 22, 2006 | 12:29 PM
Default Re: Infinity Kappa 60.7cs or Polk Audio db6500 (Earthworm Jim)
To the top....
Old Jun 22, 2006 | 05:35 PM
JSPECSIR's Avatar
kappa's are 2 ohm make sure your amp is 2 ohm stable and the 2 ohm rating does not exceed their power handling. and yeah my vote would be the kappa's, but both companies are very good.
Old Jun 22, 2006 | 07:29 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Earthworm Jim &raquo;</TD></TR><TR><TD CLASS="quote">Thanks in advance. If there's anything better please post the site </TD></TR></TABLE>OK... http://www.hertzaudiovideo.com/default_en.htm
check out the MILLE MLK2 94
Old Jun 22, 2006 | 08:48 PM
Mik3's Avatar
Default Re: Infinity Kappa 60.7cs or Polk Audio db6500 (fcm)
http://www.etronics.com/produc...607cs
are those the same?
Old Jun 23, 2006 | 10:42 AM
fcm's Avatar
fcm
Old Fart
Default Re: Infinity Kappa 60.7cs or Polk Audio db6500 (Mik3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mik3 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.etronics.com/produc...607cs
are those the same?</TD></TR></TABLE> Same as what, as you are replying to me I will say they are not the same.
If you mean the same as these... http://www.crutchfield.com/S-Q...607CS I would say yes, [model number being the same] but maybe you where just being redundant, and the price was the issue, however you may want to read the fine print under warranty, Crutchfield is an authorized dealer for Infinity and etronics is not 94
Old Jun 23, 2006 | 12:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Same as what, as you are replying to me I will say they are not the same.
If you mean the same as these... http://www.crutchfield.com/S-Q...607CS I would say yes, [model number being the same] but maybe you where just being redundant, and the price was the issue, however you may want to read the fine print under warranty, Crutchfield is an authorized dealer for Infinity and etronics is not 94</TD></TR></TABLE>
So...I should go with the Infinity, they have a warranty of 3 years
Old Jun 23, 2006 | 03:05 PM
fcm's Avatar
fcm
Old Fart
So...I should go with the Infinity, they have a warranty of 3 years </TD></TR></TABLE>Both sets linked are the same speaker, the point Mik3 was trying to make was that they were cheaper at etronics.com then at Crutchfield I just pointed out that unlike Crutchfield, etronics is not an authorized Infinity dealer, so you will get no manufacturers warranty. 94
Old Jun 23, 2006 | 05:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Both sets linked are the same speaker, the point Mik3 was trying to make was that they were cheaper at etronics.com then at Crutchfield I just pointed out that unlike Crutchfield, etronics is not an authorized Infinity dealer, so you will get no manufacturers warranty. 94</TD></TR></TABLE>
But the Infinity's out of the two are the better purchase right? I mean, it seems as though I'll need a good healthy amp right? What kind should I get? I'm not too experienced in the stereo section.
Old Jun 23, 2006 | 11:53 PM
Mik3's Avatar
Ops, my bad. Yes i meant the same as the ones that the op had posted. Sorry for the confusion. Man, I never though about that fcm, thanks.
Old Jun 24, 2006 | 06:49 AM
fcm's Avatar
fcm
Old Fart
But the Infinity's out of the two are the better purchase right? I mean, it seems as though I'll need a good healthy amp right? What kind should I get? I'm not too experienced in the stereo section.</TD></TR></TABLE> Yes, in my opinion the Infinity 60.7cs are the better speaker, it comes with a better x-over, [18dB/oct and adjustable tweeter output] and a sensitivity of 95dB and 3 years of warranty. 94
Old Jun 26, 2006 | 06:12 AM
honda_runner's Avatar
yea, go with the kappas man
Old Jun 26, 2006 | 08:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Yes, in my opinion the Infinity 60.7cs are the better speaker, it comes with a better x-over, [18dB/oct and adjustable tweeter output] and a sensitivity of 95dB and 3 years of warranty. 94</TD></TR></TABLE>
So what kind of amp should I go with? I'll be getting four of the 60.7cs'.
Old Jun 26, 2006 | 12:16 PM
fcm's Avatar
fcm
Old Fart
They are 90W 2 ohm speakers, so I would want a 4x100W rms into 2 ohms amp, [4x50W into 4 ohms]. 94
Old Jun 27, 2006 | 05:17 PM
CFactor's Avatar
FCM i may be wrong but most amps if you convert from 4 ohm to 2 ohm wont double your power rating. You will lose a percentage when dropping ohmage. As far as the infinity speakers they are definately a good choice. One problem with the component speakers are a metallic sound coming from the tweeter, which you can hopefully remedy by either using the switch (if provided) or placing the tweeter speaker wires in the -2db slot. This will tone the tweeter down.
The one question is will it fit without spacers.
Old Jun 27, 2006 | 06:33 PM
fcm's Avatar
fcm
Old Fart
Default Re: (CFactor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CFactor &raquo;</TD></TR><TR><TD CLASS="quote">FCM i may be wrong but most amps if you convert from 4 ohm to 2 ohm wont double your power rating. You will lose a percentage when dropping ohmage. As far as the infinity speakers they are definately a good choice. One problem with the component speakers are a metallic sound coming from the tweeter, which you can hopefully remedy by either using the switch (if provided) or placing the tweeter speaker wires in the -2db slot. This will tone the tweeter down.
The one question is will it fit without spacers.</TD></TR></TABLE>No, you are correct, "most amps" that do show a doubling of watts when impedance is dropped in 1/2 will not deliver exactly twice the wattage other factors other then the speakers impedance will also have an effect, but it's close enough to count.
They will not fit the oem mount without the "mounting ring", [supplied] but then I would not recommend mounting them to the oem plastic speaker housing anyway, I would recommend custom MDF housings to replace the plastic ones. 94
Old Jun 27, 2006 | 06:46 PM
CFactor's Avatar
why would you go with the MDF just for added stability?
Old Jun 27, 2006 | 06:52 PM
fcm's Avatar
fcm
Old Fart
A speaker will always sound better mounted to wood then the same speaker mounted to just about anything else, also an MDF housing would have a lot more mass, [better bass response], and it can be made to fit the speaker exactly. 94
Old Jun 27, 2006 | 08:32 PM
CFactor's Avatar
Default Re: (fcm)
good point
Old Jun 28, 2006 | 08:13 AM
Default Re: (fcm)
The one question is will it fit without spacers.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">No, you are correct, "most amps" that do show a doubling of watts when impedance is dropped in 1/2 will not deliver exactly twice the wattage other factors other then the speakers impedance will also have an effect, but it's close enough to count.
They will not fit the oem mount without the "mounting ring", [supplied] but then I would not recommend mounting them to the oem plastic speaker housing anyway, I would recommend custom MDF housings to replace the plastic ones. 94</TD></TR></TABLE>
So what's the better amp choice? (Note: I'll probably pick up a 10in sub).
Old Jun 28, 2006 | 12:40 PM
OMG WTF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">OK... http://www.hertzaudiovideo.com/default_en.htm
check out the MILLE MLK2 94</TD></TR></TABLE>
wow those specs look awesome. just curious where do they sell these and how much?
Old Jun 28, 2006 | 12:44 PM
fcm's Avatar
fcm
Old Fart
Default Re: (Earthworm Jim)
So what's the better amp choice? (Note: I'll probably pick up a 10in sub).</TD></TR></TABLE> Any 4 ch. amp that makes at least 90W rms into a 2 ohm load, [most any 4x50W rms into 4 ohms] then a mono block sub amp to match your sub.
This one would work for the high-pass and the low-pass as long as the sub you get is a 250-275 watt continuous into a 4 ohm load... http://www.infinitysystems.com/carau...er=REF&Cat=AMP 94
Sorry link will not work, it's the Infinity REF5761A a 6ch amp.
skingfreak
Audio / Security / Video
19
Feb 24, 2008 04:49 PM
TedR719
Mar 11, 2007 12:47 PM
dk015
Jul 29, 2005 01:21 PM
TolnaPunk
Jul 17, 2005 03:04 PM
Ziggie
10
Jul 8, 2003 12:31 AM
