help me pick parts
ok guys, so im wanting to pick some engine parts out for my car, its the stock d16a6, and im lookin for a good engine rebuild kit, cam, and intake, ive found the engine kit, but cant seem to find a cam for a non-vtec head, and the only intake i can find is for a y8. so if anyone can help me find a cam, and intake, or if you can tell me if the y8 intake will work on my car, it would be greatly appreciated
Thanks
Thanks
d is a d man. almost every part can be swapped from and d series motor. just check first. i think but am not to sur about the cams being swapable but the intake manifold. (im guessing you meant that by intake) should go on perfectly.
any d-series intake manifold will fit. there's a conspiracy on which one the y8 or z6 due too which one flows better. but if you want cheap and better flow. find a a6 manifold bore out your tb and port match the manifold. thats just me though now as for cams i would go with exospeed as stated they speacialize in a6's
http://exospeed.com/category.php?id=229
i was thinkin about the stage 3..... so with that i gotta send my cam to them?
dang, i cant really be out my car for a while, the only other car i have to drive other than my rex is a truck that gets like 6mpg!!!, so anyone know if the cam outta 1.5l 8 valve will work on the a6? cuz if it does i can just throw that in my car til my cams done.... if not anyone got a cam they will selll CHEAP?
i recommend the stage II. you didn't really specify that you were building an all out race car..... reving an A6 block to 8,000+ rpms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockcivic103 »</TD></TR><TR><TD CLASS="quote">dang, i cant really be out my car for a while, the only other car i have to drive other than my rex is a truck that gets like 6mpg!!!, so anyone know if the cam outta 1.5l 8 valve will work on the a6? cuz if it does i can just throw that in my car til my cams done.... if not anyone got a cam they will selll CHEAP?</TD></TR></TABLE>
the 8valve cam will NOT work in the A6 head. I know at times exospeed has cores available. you might want to contact them.
alright, i didnt read that they have cores available until afer you said that...lol.... and i wasnt totally sure if the cam from the 8v would work, and i digured it wouldnt
go to the junk yard man you can score on a6 cams for cheap even in our classifieds. i didnt no you were building an all out all motor a6. but anyway if your concerned about gas homie your best bet is the stage 2. its still a good cam. i would think it would be great on gas compared against the stage 3. but with the stage 3 to get maximum potential you would have too work on the head a bit even though you can run it on a stock one. plus it pulls way past redline might wanna invest on some upgraded valves and springs if you want that and a chipped ecu. oh yeah you can also ask them if they have cores available as stated by streetwerkz.
leochilo
Jul 20, 2009 12:16 AM
