CEL Code 1 - Primary Oxygen Sensor - b16a2 swap on 96 civic
Old Jun 21, 2006 | 09:11 PM
pinoyboy204's Avatar
Default CEL Code 1 - Primary Oxygen Sensor - b16a2 swap on 96 civic
I'm getting ticked off that my CEL keeps popping up about 30 mins. of driving and especially when gunning it. Not to mention the annoying code 20 - ELD. I've already replaced the primary oxygen sensor 3 times 2 with denso units and 1 bosch. this is a 4 wire.
my setup is as follows
b16a2 swap, no catalytic converter, welded a flex pipe to join the downpipe and b pipe, running obd1 p30 ecu via obd2a-obd1 jumper harness.
could not having a cat be the problem??? what other things do i check for?
Old Jun 22, 2006 | 04:22 AM
EE_Chris's Avatar
Default Re: CEL Code 1 - Primary Oxygen Sensor - b16a2 swap on 96 civic (pinoyboy204)
Is the wiring harness stock or did you do anything to it...like lengthen it?
Old Jun 22, 2006 | 05:33 AM
Default Re: CEL Code 1 - Primary Oxygen Sensor - b16a2 swap on 96 civic (EE_Chris)
i'm not too sure,my friend did the wiring. is there any way to check if the wiring is bad? I have a multimeter, what should i check for?
Old Jun 22, 2006 | 10:46 AM
ttt...
Old Jun 22, 2006 | 11:54 AM
prison_snitch's Avatar
well if you fix code 1 dont expect 20 to go away..
Old Jun 22, 2006 | 11:56 AM
Default Re: (prison_snitch)
i really don't care about code 20, just need to get rid of this damn code 1. any other ideas guys??
Old Jun 22, 2006 | 12:05 PM
the jdmchop's Avatar
Default Re: (pinoyboy204)
you sure its code 1 and not ten, i made that simple mistake and replaced my o2 wen it was just a bad IAT sensor
Old Jun 22, 2006 | 12:38 PM
Default Re: (anti-lag aka JDMCHOP)
i'm pretty sure, because when i get my CEL my car would hesitate.
Old Jun 22, 2006 | 12:41 PM
yea cause i thought wen i check my code it flashed once, but it was a paused blink which means ten and not a quick blink which is one
check your wiring maybe one of the grounds is not grounding?
Old Jun 22, 2006 | 12:50 PM
the grounds are fine, one to the tranny and one to the cylinder head. would a bad ground cause that o2 sensor problem????
Old Jun 22, 2006 | 12:51 PM
no the grounds for the sensor
i belive power,signal,two grounds on the sensor
Old Jun 22, 2006 | 12:59 PM
so do I use a multi-meter? and test each black wire to the battery (-) side? sorry to sound like such a noob!
Old Jun 22, 2006 | 01:24 PM
test ligh, power the lead wire then backprobe the wires to check for ground!
Old Jun 22, 2006 | 02:31 PM
Slamaccord's Avatar
Sounds like a wiring problem. Double check it!!
D Grade
Aug 14, 2016 07:57 PM
joeli27
May 31, 2010 09:40 PM
vtecmonster001
Apr 9, 2009 11:50 PM
EKen9
Jul 6, 2002 04:20 AM
