Code 10 and 8 in 93 SI w/B16A2
Old Jun 21, 2006 | 03:32 PM
vtec25's Avatar
Default Code 10 and 8 in 93 SI w/B16A2
What do i do about these codes? And BTW i am running a P72 ecu at the moment.
And where is the TDC sensor? i never heard of it till now.
Thank You
Old Jun 21, 2006 | 03:36 PM
Slamaccord's Avatar
Default Re: Code 10 and 8 in 93 SI w/B16A2 (vtec25)
Distributor related. Correct me if I'm wrong anyone.
Old Jun 21, 2006 | 04:19 PM
jdmsiR20's Avatar
Default Re: Code 10 and 8 in 93 SI w/B16A2 (Slamaccord)
FYI, there is an ecu thread stickied at the top of the forum...
code 8 TDC sensor
code 10 IAT sensor
for the TDC sensor, its either you've skipped a tooth on your timing (you'd be able to tell)... or parts of your dizzy are bad. make your life easy and try another ecu. if you still get those codes, then replace the dizzy.
IAT (intake are temp) is the sensor on 99-00 si's that plugs into the intake arm. on your hatch its a white sensor previously on the back of the intake manifold. extend the wiring, and plug it into the intake arm, or mount the old sensor onto your intake manifold (requires drilling).
Old Jun 21, 2006 | 06:34 PM
vtec25's Avatar
Default Re: Code 10 and 8 in 93 SI w/B16A2 (jdmsiR20)
Before i make another topic. I just blew one after another ignition coils inside the dizzy.
Could this be cuz of code 8????
Old Jun 22, 2006 | 12:13 AM
jdmsiR20's Avatar
yessir, definitely possible.
i would see if something is accidentally grounded, or wet. dont keep on buying coils, cause they're just gonna keep blowing. check your grounds, fuses, and stupid stuff like that. search too
mouab18c1
Feb 23, 2009 09:08 AM
dont_tri
Jul 27, 2007 10:17 AM
SoHc94
Sep 11, 2006 08:58 PM
ppl talk bout my old name
Apr 19, 2006 07:23 PM
