Code 10 and 8 in 93 SI w/B16A2
What do i do about these codes? And BTW i am running a P72 ecu at the moment.
And where is the TDC sensor? i never heard of it till now.
Thank You
Thank You
Re: Code 10 and 8 in 93 SI w/B16A2 (Slamaccord)
FYI, there is an ecu thread stickied at the top of the forum...
code 8 TDC sensor
code 10 IAT sensor
for the TDC sensor, its either you've skipped a tooth on your timing (you'd be able to tell)... or parts of your dizzy are bad. make your life easy and try another ecu. if you still get those codes, then replace the dizzy.
IAT (intake are temp) is the sensor on 99-00 si's that plugs into the intake arm. on your hatch its a white sensor previously on the back of the intake manifold. extend the wiring, and plug it into the intake arm, or mount the old sensor onto your intake manifold (requires drilling).
code 8 TDC sensor
code 10 IAT sensor
Re: Code 10 and 8 in 93 SI w/B16A2 (jdmsiR20)
Before i make another topic. I just blew one after another ignition coils inside the dizzy.
Could this be cuz of code 8????
Re: Code 10 and 8 in 93 SI w/B16A2 (vtec25)
yessir, definitely possible.
i would see if something is accidentally grounded, or wet. dont keep on buying coils, cause they're just gonna keep blowing. check your grounds, fuses, and stupid stuff like that. search too
dont_tri
07-27-2007 10:17 AM
ppl talk bout my old name
04-19-2006 07:23 PM
01PYTypeR#1140
12-31-2003 10:05 AM
