what to pull/disconnect for compression test
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">pull out your spark plugs so you can turn the crank easier. Thats about it.</TD></TR></TABLE>
i know that.. im just wondering what fuse to pull before i do it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">u dont need to pull out any fuse.</TD></TR></TABLE>
wont it clog the injectors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">my bad, pull out the fuel pump fuse
is that in the fues box thats under the hood? doesnt the clock/radio fuse control the ecu which controls the injectors?
</TD></TR></TABLE>is that in the fues box thats under the hood? doesnt the clock/radio fuse control the ecu which controls the injectors?
I didn't take any fuses out on my car. Compression was great and it still runs great if that makes you feel any better.
I disconnect all 4 fuel injectors and leave all fuses in the car. The wire connectors to the injectors just pop right off. This way I know no fuel will enter the chamber. With the fuel pump off there is still going to be some fuel pressure that will let the injectors work for a while until all the pressure is bled out.
Spark plugs need to be out also, but that's obvious because that's were the compression test tool goes.
either way will work, and a little fuel in there will not really hurt anything, but I'm **** like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">pull out your spark plugs so you can turn the crank easier. Thats about it.</TD></TR></TABLE>why would u need to turn the crank??
here
linky---> http://www.c-speedracing.com/h...t.php
only diff. is for a h22 u disconnect the coil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Luder »</TD></TR><TR><TD CLASS="quote">why would u need to turn the crank??</TD></TR></TABLE>
You're going to be cranking the engine over many times and it'll make it a lot easier on your battery and starter if the engine isn't making compression.
Yeah, the compression tester goes in the spark plug hole for the cylinder you are testing and seals the cylinder just like the spark plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Luder »</TD></TR><TR><TD CLASS="quote">but isn't that the whole point of a compression test?</TD></TR></TABLE>
you can only test one cylinder at a time.
crazyemokid
35
Jun 8, 2006 12:08 PM
BlueShadow
25
Jul 8, 2005 09:43 AM
JDM_ITR
Jul 6, 2003 09:53 AM
