how do i do a compression test ??
Old Apr 17, 2002 | 08:27 AM
zcivicz's Avatar
Default how do i do a compression test ??
its a 90 crx Si motor sitting in my garage waiting to be rebuilt.
i wanna know if you can test it while its out of the car before i swap it in my DX.
anyone??
thanks!
Old Apr 17, 2002 | 08:56 AM
HumanResource's Avatar
Default Re: how do i do a compression test ?? (zcivicz)
Just unplug the fuel pump fuse (or acutal pump if it's gutted)
remove all the spark plugs. Install the comp tester and at WOT, give it about 4-5 turns, Then read record then do the next one.
Old Apr 17, 2002 | 10:38 AM
EVOCELICA's Avatar
New User
Default Re: how do i do a compression test ?? (Chris90STD)
you'll need the tranny to be attached and to have the starter bolted on to do it with it out of the car. You won't get an accurate reading unless the motor is hot so it is not really worth trying.
Old Apr 17, 2002 | 10:56 AM
Aahj's Avatar
Default Re: how do i do a compression test ?? (EVOCELICA)
That's what you have to do, but like he said, it won't give you an accurate reading.
good luck,
aj
severe97
16
Nov 6, 2007 05:34 PM
tpr
Sep 13, 2005 09:00 AM
SupRlude01
Nov 4, 2003 06:45 AM
J-g-D-s-M-r
Sep 29, 2003 02:32 AM
B_1_8_hatch
Jun 22, 2003 07:42 AM
