does anyone have piping running from wastegate to the downpipe?
Old Apr 17, 2002 | 07:48 AM
stealthteg's Avatar
Default does anyone have piping running from wastegate to the downpipe?
i'm wondering if anyone makes this or has one so i have an idea on how to do it. Right now the wastegate is just letting extra exaust into the engine bay.. this is no good cause its too hot in there to begin with.. If anyone has pictures or experiences doing this it would be greatly appreciated...
Old Apr 17, 2002 | 07:50 AM
SlowB16's Avatar
Default Re: does anyone have piping running from wastegate to the downpipe? (stealthteg)
You can get a peice of tube made at a muffler shop. You know that running with the wastegate open gives more power right? Why dont you just get a tube to run the exhaust from the WG underneath the car
Old Apr 17, 2002 | 07:55 AM
stealthteg's Avatar
damn good point i never thought of that, i passed inspection alrighty with the open wastgate.... thanks for the advice... any type of metal sugestions?
Old Apr 17, 2002 | 08:41 AM
dbman96's Avatar
New User
Cheap pep-boys 1.5" flex pipe will get it under your car no problem, but I don't know where SlowB16 gets his information. There is no power difference between open wastegate and a PROPERLY built closed-loop setup.
Old Apr 17, 2002 | 08:45 AM
rtype11's Avatar
judas priest, ozzy, sabbath, iron maiden, kiss - just match the grade of steel to the flange you are ysing for the wg dump, low carbon steels weld easiest.
Old Apr 17, 2002 | 09:31 AM
X2BOARD's Avatar
Default Re: does anyone have piping running from wastegate to the downpipe? (dbman96)
? An open wastegate dumptube would promote quicker spool even compared to a 'properly designed' closed loop system, no ?
Old Apr 17, 2002 | 09:35 AM
bgod's Avatar
Default Re: does anyone have piping running from wastegate to the downpipe? (X2BOARD)
agree, just use the dump-tube. it would be a pain in the *** to get a closed dump tube mounted on now. you would need to remove the downpipe.
i used to run a closed dump tube and the car was a little too quiet.
boostdummy
Feb 12, 2006 04:13 AM
sixphak
Welding / Fabrication
Feb 15, 2005 06:47 PM
MyWhiteCivic
Sep 21, 2002 12:36 PM
udctown
Sep 13, 2001 07:50 AM
bigTom
Jul 19, 2001 05:44 PM
