Will EK Rear LCA fit an EG?
Old Jun 20, 2006 | 08:44 PM
TORQUE MONSTER's Avatar
Default Will EK Rear LCA fit an EG?
I searched but came up dry.. Will an EK rear LCA fit an EG?
Thanks
Old Jun 20, 2006 | 08:49 PM
JDM-EJ1's Avatar
Default Re: Will EK Rear LCA fit an EG? (TORQUE MONSTER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TORQUE MONSTER &raquo;</TD></TR><TR><TD CLASS="quote">I searched but came up dry.. Will an EK rear LCA fit an EG?
Thanks</TD></TR></TABLE>
No.
Old Jun 20, 2006 | 09:48 PM
gold_ef's Avatar
is this why itr lca's will fit 88-00 civics?
Old Jun 20, 2006 | 09:51 PM
gold_ef's Avatar
Default Re: (gold_ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gold_ef &raquo;</TD></TR><TR><TD CLASS="quote">is this why itr lca's will fit 88-00 civics?</TD></TR></TABLE>
but i think the struts mount diferently between eg's and ek's
Old Jun 20, 2006 | 10:06 PM
Downey's Avatar
technically, yes the would "fit". they are similar in design, but about 3" longer. they would give you some crazy negative camber.
the shock mounts on the EK as also narrower. most companys sell rear shocks that fit both EK and EG but they include small 1/4 thick spacers for the car with narrower LCA bushings.
so No, dont use EK control arms on an EG. Use DC2 integra or EG ones. ITR rear lca's fit a CRX because they use the same style LCA. EF, EG and DC2 arms are all interchangeable. EK is the odd ball
Old Jun 20, 2006 | 10:53 PM
EK k kay's Avatar
No, ITR will not fit 96-00 civics.
Old Jun 20, 2006 | 11:01 PM
B7AudiA4's Avatar
Default Re: (EK k kay)
been kind of thinking about this for a while also...
Old Jun 20, 2006 | 11:18 PM
fmrprojects's Avatar
Default Re: (FutureITR)
no
Old Jun 21, 2006 | 05:13 AM
Default Re: (fmrprojects)
reason I'm asking is, I have a set of EK shocks.. I guess I can shime down teh bushing or spread the shock fork out a bit.
Thanks everyone.
although...-3 camber might look BAD ***
Old Jun 21, 2006 | 07:46 AM
littleredcivic's Avatar
NO!!! do not spread your shock. pull out your EG control arms and just change the bushing to an EK bushing for the lower strut mount. its cheap and works well.
Old Jun 21, 2006 | 07:52 AM
SkoundrelUSA's Avatar
cute little bastard
I bought EKs by mistake and rigged mine to work doing the spacer trick. MY camber isn't that bad surprisingly
allstarr7
Mar 18, 2008 07:20 PM
dc2vu
Oct 12, 2005 10:32 PM
H22A_HB
Nov 21, 2004 11:14 PM
vizsual00
24
May 26, 2004 10:09 PM
chad
Dec 15, 2003 01:21 PM
