b16 block, type r head?
Old Jun 20, 2006 | 08:22 PM
vlc92189's Avatar
Default b16 block, type r head?
Alright, someone i know has the stock 2000 si block with a type r head.. how could i tell if its really a type r head, and what is the numbers he should be putting down? has this ever been done, i mean im sure it has, but whats it called.. oh and is it possible to have your nitrous hooked up to your gas pedal so when you hit a certain rpm that the ntirous kicks in? just wannaknow if hes bullshittign or not.
Old Jun 20, 2006 | 08:30 PM
BlueIntegraBoy's Avatar
Default Re: b16 block, type r head? (vlc92189)
An ITR head will have green paint near the distributor if it hasn't been worn off yet. An ITR head isn't much different from a B16 head aside from the cams, valvetrain, and PnP. He shouldn't expect totally huge numbers but a slight difference. It's called a head swap. Yes, you can hook up nitrous to kick in at a certain RPM.
Old Jun 21, 2006 | 05:09 AM
mvs's Avatar
mvs
around here we call that the poor man's typer
Old Jun 21, 2006 | 05:35 AM
black_EM1's Avatar
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">An ITR head will have green paint near the distributor if it hasn't been worn off yet. An ITR head isn't much different from a B16 head aside from the cams, valvetrain, and PnP. He shouldn't expect totally huge numbers but a slight difference. It's called a head swap. Yes, you can hook up nitrous to kick in at a certain RPM.</TD></TR></TABLE>
What he said. Also, about the nitrous thing, it's either a window switch, which opens the N02 for a certain rpm - rpm, or a pill, which pens it at a certain given rpm
Modified by black_EM1 at 6:46 AM 6/21/2006
Modified by black_EM1 at 6:47 AM 6/21/2006
crxvtecturbo
May 10, 2014 05:12 PM
TurboEM1
Dec 26, 2009 07:50 PM
slob20ef
13
Dec 2, 2009 11:18 AM
RSant
Apr 17, 2007 05:43 PM
cacahead1
Jun 11, 2005 07:29 AM
