Where do i get the tool that does this?
Ek Forever y0!
i need a new username »
Check Engine came on, and got this error:
PO133 Mod$0D
02 Sensor
CKT Slow Response
need to replace?
PO133 Mod$0D
02 Sensor
CKT Slow Response
need to replace?
What's the name of this tool and where do i get one? I feel like im the only honda guy that doesnt have one. Autozone?
It's some kind of ecu reading tool or something.. Sorry for the Nub question.
Re: Where do i get the tool that does this? (ek forever guy)
from what i am reading your o2 sensor is bad, right? go to your local part store and pick up a o2 sensor and the socket to remove it. the socket doesn't cost much, as for the o2 sensor, that's a different story!
good luck
good luck
Re: Where do i get the tool that does this? (philosofy1)
Go to your local autozone and see if they sell scanners. I think the cheap universal ones are around 100.
If it's OBD-1 you can stick a paperclip in the jumper, turn the key to the on position and count the long & short flashes of the check engine light.
Re: Where do i get the tool that does this? (nota-eg)
Originally Posted by Relic1
go to a parts store, have them scan your car for codes. it's free. no need to buy a scanner of your own.
I told you in the other thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">A paper clip and https://honda-tech.com/zerothread/1171263
Also, there is a gren clip by your ecu you stick the paper clip in.</TD></TR></TABLE>
You can scan your own codes by using a paper clip, do a search or go to the FAQ. It tells how and what each code means...No need to spend money!
If it's the O2 sensor I had to remove mine when I changed the header on my EG. I used a number 21 open wrench and it worked fine. Not sure on the EK though.
Ek Forever y0!
Re: (Manga_Spawn)
Sorry, i tried to pull that quote from another thread. It's not my post. I was just curious what tool does that. Now I know, Much appreciated. Sorry for any trouble.
Re: Where do i get the tool that does this? (jdm_bones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones »</TD></TR><TR><TD CLASS="quote">You can scan your own codes by using a paper clip, do a search or go to the FAQ. It tells how and what each code means...No need to spend money!</TD></TR></TABLE>
X2
X2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg »</TD></TR><TR><TD CLASS="quote">
If it's OBD-1 you can stick a paperclip in the jumper, turn the key to the on position and count the long & short flashes of the check engine light.</TD></TR></TABLE>
Works on obd2 as well.
no what everyone is saying.. go to autozone.. they loan tools out for free.. you just pay the fee for what it cost.. so in that case if youy decided to keep it.. you payed for it.. but you can take it home.. and when your done with it.. bring it back and they will give you your money back.
2000Si_b16A2
15
12-17-2005 06:13 PM
