Yea I Have question to all the Mechanic's out there!??!?
Old Apr 17, 2002 | 07:30 AM
TurboB18C1's Avatar
Default Yea I Have question to all the Mechanic's out there!??!?
If you over tightin the 3 bolts that hold in the fuel rail, does that cause the engine to misfire? i am assuming that there is a leak in my fuel system becasue the check engine lights keeps jumping a CYL. 2/CYL.3 misfire code.
I did put in new injectors on a AEM fuel rail with a B&M fuel Pressure. Reg.
Could it also be my seals on the injectors that are leaking!!???! plus on my fuel pressure gauge the neddle goes back and fourth extrmely rapdily, guessing that there is a leak in my fuel system.
Old Apr 17, 2002 | 07:55 AM
salbaje's Avatar
Default Re: Yea I Have question to all the Mechanic's out there!??!? (TurboB18C1)
check all the O rings and seals on the injectors.
Old Apr 17, 2002 | 08:10 AM
riceboy's Avatar
you got a pic of where the fuel pressure regulator is mounted??
[Modified by riceboy, 5:10 PM 4/17/2002]
Old Apr 17, 2002 | 08:21 AM
TurboB18C1's Avatar
Default Re: Yea I Have question to all the Mechanic's out there!??!? (riceboy)
The reg. is located where the stock fuel pressure reg, is located. I have a 98 Integra GS-R with a Greddy Turbo Kit
Old Apr 17, 2002 | 08:43 AM
Crazydave's Avatar
is your fuel presure gauge leaking
So it throws a code with the Aem fuel rail and new injectors
Does is code without the B&M FPR?
does it code with stock fuel rail and old injectors?
Does it code with stock fuel rail and new injectors
Does is code with aem fuel fail and old injectors?
Start taking off mods.... and check all fuel lines and o-rings.
are you getting good spark to 2 & 3?
does it do it hot and cold?
are your plugs good.. did you look at them?
[Modified by Crazydave, 5:51 PM 4/17/2002]
Old Apr 17, 2002 | 09:27 AM
TurboB18C1's Avatar
Default Re: Yea I Have question to all the Mechanic's out there!??!? (Crazydave)
is your fuel presure gauge leaking --- no it is not leaking
So it throws a code with the Aem fuel rail and new injectors ---yep
Does is code without the B&M FPR? i had the B&M on the stock fuel rail
Cant put in old injectors wiht the greddy FMU
Did not check yet
Cant do i thnk
No way cant do man
yea i am i change my whole ingnation
never drivin so it real didnt get hot
yea bought new ones cost me about 80$$
NickMorneau
May 30, 2013 05:15 PM
ITRfaithful
May 13, 2004 11:47 AM
zseeanz
Apr 5, 2004 07:48 AM
Shadow Templar
Jan 30, 2004 08:25 PM
TurboB18C1
Apr 17, 2002 07:48 AM
