2000 EX Civic Mechanical Defects
Old Jun 20, 2006 | 11:26 AM
HOAzSN's Avatar
Default 2000 EX Civic Mechanical Defects
my brother recently installed a cd player into my 2000 civic ex, and it seems he installed it wrong and alot of things got short circuit, (i.e sunroof no longer works, passenger window doesnt work, passenger window cant be controlled by driver side, power lock stopped working). where would i begin to fix this ?
Old Jun 20, 2006 | 11:33 AM
sicones's Avatar
Default Re: 2000 EX Civic Mechanical Defects (HOAzSN)
check the fuses, and thats not a "Mechanical Defect", its called a stupid brother
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOAzSN &raquo;</TD></TR><TR><TD CLASS="quote">my brother recently installed a cd player into my 2000 civic ex, and it seems he installed it wrong and alot of things got short circuit, (i.e sunroof no longer works, passenger window doesnt work, passenger window cant be controlled by driver side, power lock stopped working). where would i begin to fix this ?</TD></TR></TABLE>
to a shop! electrical problems are time consuming and troubleshooting is a pain in the ***! if your handy with a voltage meter and have couple of hours to dedicate to this then you might be able to do it. if not, it'll be easier and less of a headache if you just had a shop do it. trust me
Old Jun 20, 2006 | 11:34 AM
tsdenny's Avatar
check/replace fuses
if it still blows out then remove the deck and get it reinstall by a professional
philosofy1's Avatar
Default Re: 2000 EX Civic Mechanical Defects (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote"> and thats not a "Mechanical Defect", its called a stupid brother</TD></TR></TABLE>
agreed 100%
Old Jun 20, 2006 | 11:55 AM
HOAzSN's Avatar
yeah the fuses blow evertime we replace it..by what deck are you talking about?
Old Jun 20, 2006 | 12:05 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOAzSN &raquo;</TD></TR><TR><TD CLASS="quote">yeah the fuses blow evertime we replace it..by what deck are you talking about?</TD></TR></TABLE>
they keep blowing because you have a short. the problem won't be corrected if you keep changing fuses. you need to find the short!
read my first post:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
to a shop! electrical problems are time consuming and troubleshooting is a pain in the ***! if your handy with a voltage meter and have couple of hours to dedicate to this then you might be able to do it. if not, it'll be easier and less of a headache if you just had a shop do it. trust me </TD></TR></TABLE>
Old Jun 20, 2006 | 12:59 PM
sicones's Avatar
Default Re: 2000 EX Civic Mechanical Defects (philosofy1)
you dont need to take it to a shop, if you installed the radio yourself or your brother, go back and check your wiring, read the installation manual that came with the radio there is a wealth of knowlege in there, do some searching on the internet "car radio install", this stuff is easy goodluck
Old Jun 20, 2006 | 01:09 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">you dont need to take it to a shop, if you installed the radio yourself or your brother, go back and check your wiring, read the installation manual that came with the radio there is a wealth of knowlege in there, do some searching on the internet "car radio install", this stuff is easy goodluck</TD></TR></TABLE>
i'm taking it you haven't read the whole thread. the only reason i said shop was because:
1. they can't install something simple like a radio.
2. he also stated that they keep changing out fuses and the problem is not corrected. everyone who has dealt with electrical problems on any car would know that you can change the fuses 100 times, if you don't find the short you'll never fix it!
not to mention, he also stated other things are not working right, like the sunroof, doorlocks, and windows. if it's that bad i recommended they take it to a shop before they do more damage.
so yes! yes, if they want to have it done right with no more problems, then yes they should take it to a shop. read the whole thread homie!
Old Jun 20, 2006 | 02:11 PM
sicones's Avatar
hey homie I was the one who first posted, everyone has got to start somewhere, every shop I have ever seen does complete SH*T work, loose wires twisted together auto-start ignition wires none the less, theres just to much to list.
The word professional has a new meaning in my mind.
CaptainSLO
Jul 9, 2018 09:01 AM
Drive55
Honda S2000
Jul 27, 2007 07:13 PM
turnsignalandy
May 15, 2006 08:51 PM
matman4444
Jan 13, 2006 01:11 AM
Full-Race Henry
10
Sep 22, 2003 12:13 PM
