Need help now, short block vs. long block
Getting motor replaced on 98 gsr. They want to put a long block instead of a short block. I asked if it's the same motor that I have in there right now and they said it is. What's the difference? They are going to call me later today. He said he would put everything that I have on there right now back on there.
tia (thanks in advance)
they mite be suggesting the long block because your head was krunked when your bottom end took a pouter. it all depends on what happened....heads dont like pistons or other things crashin into their combustion chambers when a rod lets loose, or, you could have had oil starvation SO bad that the cam journals are DONE, which will call for the requisite replacement...
KarbinFourteen
Mar 3, 2004 09:29 AM
