Where do i get the tool that does this?
Old Jun 20, 2006 | 09:37 AM
Libertariat's Avatar
Ek Forever y0!
Default Where do i get the tool that does this?
i need a new username »
Check Engine came on, and got this error:
PO133 Mod$0D
02 Sensor
CKT Slow Response
need to replace?
What's the name of this tool and where do i get one? I feel like im the only honda guy that doesnt have one. Autozone?
It's some kind of ecu reading tool or something.. Sorry for the Nub question.
Old Jun 20, 2006 | 10:09 AM
Relic1's Avatar
go to a parts store, have them scan your car for codes. it's free. no need to buy a scanner of your own.
Old Jun 20, 2006 | 10:23 AM
philosofy1's Avatar
Default Re: Where do i get the tool that does this? (ek forever guy)
from what i am reading your o2 sensor is bad, right? go to your local part store and pick up a o2 sensor and the socket to remove it. the socket doesn't cost much, as for the o2 sensor, that's a different story!
good luck
Old Jun 20, 2006 | 11:18 AM
nota-eg's Avatar
Default Re: Where do i get the tool that does this? (philosofy1)
Go to your local autozone and see if they sell scanners. I think the cheap universal ones are around 100.
If it's OBD-1 you can stick a paperclip in the jumper, turn the key to the on position and count the long & short flashes of the check engine light.
Old Jun 20, 2006 | 11:20 AM
Rock Meathammer's Avatar
Default Re: Where do i get the tool that does this? (nota-eg)
Its called an OBD2 code reader, and the **** basic models can be had for dirt cheap. Like $50.
philosofy1's Avatar
Old Jun 20, 2006 | 11:40 AM
cambopheonix56's Avatar
I told you in the other thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">A paper clip and https://honda-tech.com/zerothread/1171263
Also, there is a gren clip by your ecu you stick the paper clip in.</TD></TR></TABLE>
Old Jun 20, 2006 | 11:41 AM
jdm_bones's Avatar
You can scan your own codes by using a paper clip, do a search or go to the FAQ. It tells how and what each code means...No need to spend money!
Old Jun 20, 2006 | 12:13 PM
Manga_Spawn's Avatar
If it's the O2 sensor I had to remove mine when I changed the header on my EG. I used a number 21 open wrench and it worked fine. Not sure on the EK though.
Old Jun 20, 2006 | 07:14 PM
Ek Forever y0!
Default Re: (Manga_Spawn)
Sorry, i tried to pull that quote from another thread. It's not my post. I was just curious what tool does that. Now I know, Much appreciated. Sorry for any trouble.
Old Jun 20, 2006 | 07:30 PM
94civichatchback's Avatar
Default Re: (ek forever guy)
The parts store here charges something like $90 to use their computer on our car
Old Jun 21, 2006 | 06:13 AM
Ek Forever y0!
Default Re: (94civichatchback)
yeah **** that store.
Old Jun 21, 2006 | 06:27 AM
Slamaccord's Avatar
Default Re: Where do i get the tool that does this? (jdm_bones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones &raquo;</TD></TR><TR><TD CLASS="quote">You can scan your own codes by using a paper clip, do a search or go to the FAQ. It tells how and what each code means...No need to spend money!</TD></TR></TABLE>
X2
Old Jun 21, 2006 | 06:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg &raquo;</TD></TR><TR><TD CLASS="quote">
If it's OBD-1 you can stick a paperclip in the jumper, turn the key to the on position and count the long & short flashes of the check engine light.</TD></TR></TABLE>
Works on obd2 as well.
Old Jun 21, 2006 | 06:49 AM
vlc92189's Avatar
no what everyone is saying.. go to autozone.. they loan tools out for free.. you just pay the fee for what it cost.. so in that case if youy decided to keep it.. you payed for it.. but you can take it home.. and when your done with it.. bring it back and they will give you your money back.
dj211855
Engine Management and Tuning
Aug 28, 2011 11:52 PM
Kaya2763
Oct 28, 2010 06:39 AM
mierock
Honda Civic (2001 - 2005)
Jan 7, 2009 02:55 PM
2000Si_b16A2
15
Dec 17, 2005 06:13 PM
Enfo
Feb 3, 2004 10:59 PM
