Oxygen Sensor
Old Oct 28, 2010 | 05:56 AM
Kaya2763's Avatar
Default Oxygen Sensor
I have a no vtec 1995 Honda Accord Lx 2.2L. The engine light is on and I changed the oxygen sensor in front by the exhast manifold. Does this car have a downstream o2 sensor? where can I buy?
Old Oct 28, 2010 | 06:13 AM
GhostAccord's Avatar
Default Re: Oxygen Sensor
Yes it does have a secondary O2, you can buy one anywhere O2 sensors are sold. Before you replace both O2 sensors, did you retrieve the codes that were stored on the ECU? If so what were the codes?
When the engine light is on (check engine light or CEL) that means there are codes stored on the ECU.
Old Oct 28, 2010 | 06:18 AM
Kaya2763's Avatar
I have tried NAPA, rockauto and others. I found one a 96 prelude s and a 96 Odyssey LX but can a F22A1 sensor Fit my F22b2?
Old Oct 28, 2010 | 06:29 AM
What engine light code do you have?
Old Oct 28, 2010 | 06:32 AM
Kaya2763's Avatar
I don't have the code. I had the car check by Honda dealer.
Old Oct 28, 2010 | 06:39 AM
Wait a minute, the 95 OBD1 Accord only had the 1 O2 sensor. It doesn't have a secondary. Sorry, I was thinking that it was OBD2.
Ok So they told you it was your O2 sensor?
If you have already replaced the O2 sensor did you reset the ECU? Disconnect the battery (-) ground connection for 30 seconds or pull the back up / radio fuse for 30 seconds and that will reset the ECU and clear the CEL code. If you have the factory installed stereo you will need to make sure you have the activation code before you disconnect the battery.
Koyoloeor
Oct 13, 2005 04:57 PM
conguero
Nov 14, 2004 03:40 PM
randomd
Jul 24, 2004 04:02 AM
boiwitwhitehond
Oct 28, 2003 05:24 PM
