how do i do the S-AFC HACK!!!
Old Jun 19, 2006 | 08:57 PM
versatilezc's Avatar
Default how do i do the S-AFC HACK!!!
im trying to figure out how to trick the map because i am having alot of problems throwing a cel, i looked at the v-afc hack diagram, but the settings are different for the v-afc, does anyone know how i can do it on the s-afc or any other ways to trick the map? i tried the check valve method but im still throwing cel. also does anyone know which wire you use for the map sensor i was told it was the white wire (obd-0) do you think its possibly one of the other map wires? any help is great!
Old Jun 19, 2006 | 08:58 PM
Tippyman's Avatar
You need THREE check valves. In sequence, all pointing the right way.
Old Jun 19, 2006 | 09:37 PM
crxnj's Avatar
Default Re: how do i do the S-AFC HACK!!! (versatilezc)
3 check valves,t's,and vacuum hose
Old Jun 20, 2006 | 07:09 AM
jarvis199's Avatar
Default Re: (SloS13)
just chip your ecu man, it takes a socket adn chip and your ready to go wtih turboedit and youll be much safer...
Old Jun 20, 2006 | 11:47 AM
crxnj's Avatar
Default Re: (jarvis199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloS13 &raquo;</TD></TR><TR><TD CLASS="quote">You need to use check valves when using an AFC? Thats news to me. IIRC, the AFC hides boost from the ECU</TD></TR></TABLE>
We have manifold absolute pressure on our cars,,,not mass air flow like others...so yeah you need this
Old Jun 20, 2006 | 12:01 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloS13 &raquo;</TD></TR><TR><TD CLASS="quote">I was referring to Hondas in my post. I thought with a piggyback you didn't have to run check valves as long as you were running &lt;10psi </TD></TR></TABLE>
i wouldnt call the afc a piggyback,,,,if you're running something like turboedit,crome,uberdata,etc...then you dont have to run the check valves cause with those programs it sets the ecu up for booost....
and yeah that stock map sensor can only read about 10-11 boost,,,but i know many people running more then 15psi on stock map,,just have to get creative with the tuning
jdm91CrxSi's Avatar
i didn't even know check vavles were required for the safc..
Old Jun 20, 2006 | 02:59 PM
Tippyman's Avatar
You don't. I told him the correct way to set up check valves.
Old Jun 21, 2006 | 06:01 AM
Default Re: (Tippyman)
thank you guys for your help, i saw a post that said if you were doing the hack, you didnt need check valves b/c it changes your map sensor voltage, im not sure though another thing, does anyone know what the color of the map wire is for the s-afc? is it possibly the middle wire? I have already tried the white wire, but everytime, it throws cel (map) connect it back together without the afc and its fine. so hopefully its the other wire. thanks for the help!!
Old Jun 21, 2006 | 06:47 AM
jdm91CrxSi's Avatar
Default Re: (versatilezc)
just hook your wiring up to your harness right before your ecu, just tell me your model and year and ill give you the correct colors and wire
Old Jun 21, 2006 | 07:04 AM
Default Re: (jdm91CrxSi)
im sent jdm91
Old Jun 21, 2006 | 02:04 PM
i figured it out!!! thank you guys for all of your help, i had to splice the wire for the map right at the sensor, not at the ecu, as soon as i did, the car ran and boosted fine with no cel for map! and my car IS running fine and boosting fine at 7 lbs, with NO check valves! Thanks guys
CO_CReX
Jul 3, 2007 07:02 PM
othick
Jun 29, 2003 05:04 AM
zCivic
Nov 6, 2002 07:00 PM
Hybrid
Oct 18, 2002 02:47 PM
filetofit
Jun 20, 2002 10:53 AM
