Problems with a civic 4dr! *HELP!*
Old Jun 19, 2006 | 04:51 PM
jdm4drSi's Avatar
Banned
Default Problems with a civic 4dr! *HELP!*
Ok guys, this has been happening on and off for the past few months. The first sign the car gave me was when I was on the freeway doing about 65-75mph and the car suddenly kicked into neutral (engine-wise, would not move) and when I would accelerate, it would just rev. The rpm's would go to 3000 then drop to 0 like crazy all while I could accelerate, but the car didn't move. I posted in another forum and someone suggested that it might be a loose spark plug. So, I check all plugs, some were loose, but I didn't think they would solve anything. Well, I regapped them and tightened them snugly and it never did it again.
Well, it wasn't until about a month ago that it did something else. I was crusing down the street when the car started idling like it wanted to turn off, reacheing rpm's as low as 250. Whenever I would accelerate, it would go up and then it would normalize. At times, whenever I would accelerate while the car did that, it would do it more as I would rev the car.
Now today, I turned it on and the car kinda turned on funny. I cranked it, turned on quickly, but did the same idling thing I described above. I would accelerate it and it would do it worse. After I moved it out of the back yard, I placed it in Park and the car idled perfectly fine at about 850-1000rpm and then when I would try to accelerate, it would rev really strange, as if it wanted to turn off or struggling again.
Now, I suspect either spark (which seems good) or fuel. Obvious reasons, but I also suspect ground. What do you guys think? Maybe failing fuel pump? What should I check first?
Old Jun 19, 2006 | 05:20 PM
4doorcivic16's Avatar
my 4 door does that **** to. it wired
Old Jun 20, 2006 | 11:42 AM
jdm4drSi's Avatar
Banned
Default Re: Problems with a civic 4dr! *HELP!* (jdm4drSi)
Ok, checked the distributor, replaced it. Check the spark plugs, replaced them. Car starts much faster and better, but still wants to die when I accelerate.
Old Jun 20, 2006 | 02:32 PM
DustinM's Avatar
my friend's eg did the same thing, we sat and cleaned everything with carb cleaner, and it still did it, ended up being the injector harness for #4 was coming loose, double check electrical connections for fuel and spark for sure.
Old Jun 20, 2006 | 02:36 PM
mahatma's Avatar
My car did that once....it would idle fine but poop out on acceleration. Turned out the timing belt jumped a tooth or two.
*edit* fuel pump also sounds reasonable
Old Jun 20, 2006 | 05:51 PM
jdm4drSi's Avatar
Banned
Default Re: Problems with a civic 4dr! *HELP!* (mahatma)
Well, above I meant to say distributor cap, not distro itself. I purchased new injector o-rings if I get desperate enough to send the injectors off for inspection.
Humm, timing or electrical. I've never had any problems with my electrical and I dont get any error codes or check engine light. So I know everything electrical is up to par. The only thing I'm suspecting could be electrical is the MSD box and blaster ss coil. Anyone know how to test those? I really dont think it's spark, but I dont wanna leave it out.
I also wanna add that I would always run cleaner at every tune-up and also pumped every time I was at 1/4 of tank of fuel. So I'm skeptical of the injectors being plugged and all. Also, the night before it started, I went to put gas and it worked perfectly fine. Could the gas I pumped clogged my filter? ******* ******** if it did.
Modified by jdm4drSi at 3:30 AM 6/21/2006
Old Jun 20, 2006 | 08:32 PM
jdm4drSi's Avatar
Banned
Ok guys. Just checked wires, checked o2 and checked timing. Wires are okay, switched my current ones with previous emergency cables that are 100% working, still doing it. Did the o2 sensor test by unplugging it, still does it. I checked timing... ahh, it's off. I fixed it, but still does it.
I also wanna add that the car accelerates fine if I press the pedal gently and raise the rpms slowly, but if I press harder, then it sputters.
When I adjusted the timing, I forgot to put the stupid jumper wires. The good thing is that I didn't turn off the car, but remembered after I had already set the timing, then placed the jumper, let it run for a few minutes, then turned it off then removed the jumper wire. Do I have to do it over or should it be okay?
Old Jun 20, 2006 | 08:43 PM
IndySporty's Avatar
I would try taking the msd box out of the loop and driving the car for one day. I would bet you'll notice the problem goes away. I had one leave me stranded on I-95 at 3am in cracktown, SC and ever since then I've just used the blaster coil only, no MSD box.
Old Jun 20, 2006 | 08:46 PM
jdm4drSi's Avatar
Banned
Default Re: (IndySporty)
Worth a shot. I'll test tomorrow. How about the timing thing, should it be okay if I shorted that stupid jumper wire after I set it. I didn't turn off the car. I also restarded the car and rechecked it, still in the same setting.
Old Jun 21, 2006 | 02:53 PM
jdm4drSi's Avatar
Banned
No one...? Wow, I never expected this many people to reply on honda-tech... where the tech's at??
Old Jun 21, 2006 | 07:32 PM
mahatma's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm4drSi &raquo;</TD></TR><TR><TD CLASS="quote">I also wanna add that the car accelerates fine if I press the pedal gently and raise the rpms slowly, but if I press harder, then it sputters.</TD></TR></TABLE>
classic timing symptom
91SOHCSI
21
Nov 2, 2020 07:25 AM
manuelesr
May 14, 2007 04:28 PM
osuperjohno
Jul 31, 2005 05:32 AM
Black_eh2
Honda S2000
Apr 12, 2003 07:39 PM
RS1995
Jun 8, 2002 08:17 PM
