car wont start when its hot outside?
Old Jun 19, 2006 | 11:52 AM
89sicivic's Avatar
Default car wont start when its hot outside?
well like the title says when the weather gets hott my car just turns and turns and wont start...but when its not so hot it starts right up no prolems...any idea on what itcould it be thanks...
Old Jun 19, 2006 | 11:53 AM
crx_88_si's Avatar
Main Relay... do a search you'll find plenty on it.
Old Jun 19, 2006 | 11:54 AM
ludesrv's Avatar
Mine did the same. Main relay.
Old Jun 19, 2006 | 12:20 PM
89sicivic's Avatar
Default Re: (ludesrv)
alright thanks...will replace tonight and see if it works...
Old Jun 19, 2006 | 12:21 PM
vegaskurt's Avatar
Default Re: (89sicivic)
Fix it, dont replace it.
Old Jun 19, 2006 | 12:24 PM
89sicivic's Avatar
Default Re: (vegaskurt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vegaskurt &raquo;</TD></TR><TR><TD CLASS="quote">Fix it, dont replace it.</TD></TR></TABLE>
i dont get that comment my intention were to buy a new one...if thats what you were trying to get at....anyone know why it does this only when its hot?
Old Jun 19, 2006 | 12:27 PM
cbp_crx's Avatar
he is saying that if you seach, there are write ups on how to fix it yourself, rather than paying the money for a new one
Old Jun 19, 2006 | 12:28 PM
ludesrv's Avatar
You can re-solder them. But for the 40$ they are worth, I bought a new one, well, new to me (used, but was the new style so it didn't fail). The originals fail after 10-15 years. The solder breaks loose and doesn't connect 100% of the time. Usually when it's nice and hot and the plastic expands a bit.
Old Jun 19, 2006 | 12:38 PM
vegaskurt's Avatar
My main relay was a chronic problem out here. Cheapest replacement in town was a 2 day wait and $59. So I did a search, spent 5 min resoldering and its been solid for the last 18 months.
89sicivic's Avatar
Default Re: (cbp_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbp_crx &raquo;</TD></TR><TR><TD CLASS="quote">he is saying that if you seach, there are write ups on how to fix it yourself, rather than paying the money for a new one</TD></TR></TABLE>
gotcha on that...i have another main relay that i have off a parts car that i tested it and it tested good...
Old Jun 19, 2006 | 12:41 PM
cbp_crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89sicivic &raquo;</TD></TR><TR><TD CLASS="quote">
gotcha on that...i have another main relay that i have off a parts car that i tested it and it tested good...</TD></TR></TABLE> i was gonna say if you needed one i have a good one and i see your in dsm im about half hour away but thats cool
Old Jun 19, 2006 | 12:43 PM
89sicivic's Avatar
are the main relays the same from 88-91
Old Jun 19, 2006 | 12:44 PM
cbp_crx's Avatar
actually i dont think so, i went to a autoparts website and they have different part numbers listed for them
Old Jun 19, 2006 | 12:53 PM
89sicivic's Avatar
anybody else know if there all interchangeable between years and models?
Old Jun 19, 2006 | 01:39 PM
89sicivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">Mine did the same. Main relay.</TD></TR></TABLE>
so when car wouldn't start and the main relay was bad you didn't get spark whatso ever as well?
Old Jun 19, 2006 | 02:20 PM
Speed--Freak's Avatar
What you problem is, is that the fuel pump isn't working.
It has nothing to do with spark.
Old Jun 19, 2006 | 02:21 PM
But I don't mean your fuel pump is bad, just that the main relay is what turns it on.
Old Jun 19, 2006 | 02:22 PM
vegaskurt's Avatar
I grabbed 3 from a junk yard a month or so ago. one from a 89, one from a 90-91 and one from a 89 teg. They all worked on my car even though the teg one had a different part number and was a different color.
Anyways its easy. Open the relay up, touch each solder point with a solder gun until it pools then remove the gun. Repeat on each solder point.
Old Jun 21, 2006 | 01:12 PM
89sicivic's Avatar
anybody have any other suggestions on what it could be?
Old Jun 21, 2006 | 01:54 PM
Jaker's Avatar
It certainly sounds like the main realy. Its a 30 minute job to test this out. I suggest you re-solder the replacement used relay that you're planning on using, to be absolutely sure that when you change the relay, you're putting in something that will work all the time, and not just when its cool. When you said you tested the replacement relay, did you heat it up with a heat gun to try and simulate the conditions that it will see when you're using it in the car?
Old Jun 21, 2006 | 01:56 PM
JDM tuning702's Avatar
when it gets hot..the pads stick to the bottom and dont lift up when you turn the key..same **** happened to my 89 Si
Old Jun 21, 2006 | 02:00 PM
89sicivic's Avatar
Default Re: (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">It certainly sounds like the main realy. Its a 30 minute job to test this out. I suggest you re-solder the replacement used relay that you're planning on using, to be absolutely sure that when you change the relay, you're putting in something that will work all the time, and not just when its cool. When you said you tested the replacement relay, did you heat it up with a heat gun to try and simulate the conditions that it will see when you're using it in the car?
ill have to heat up the replacement one never did that just tested it...well thanks for the info guys ill let ya know if it works or not...
knightsef-eg
Oct 4, 2008 02:34 PM
LudeJdm
Jan 10, 2007 04:25 PM
TealCivic93
May 29, 2006 06:28 AM
esracer
Jun 25, 2005 08:08 PM
youngwon22
Sep 1, 2003 05:10 PM
