Wheel Bearings
Old Jun 19, 2006 | 11:11 AM
Kaeon's Avatar
Default Wheel Bearings
Question for you guys. I was driving under an overpass and my car makes a weird hissing,grinding sound. It sounds like its coming from the wheel area. Would worn wheel bearings cause this sound?
Old Jun 19, 2006 | 01:32 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Wheel Bearings (Kaeon)
The most common cause for the sound you describe is brake pads getting thin, possibly with the "squeaker" (metal tab) coming into contact with the rotor. Based on the strategy of starting by checking the things that are most common, easiest to check, and cheapest to fix, that's what I'd look at first.
Old Jun 19, 2006 | 02:57 PM
Kaeon's Avatar
Default Re: Wheel Bearings (nsxtasy)
Thats the first thing I checked the pads look fine although I see some etching in the rotors. I ask about wheel bearings because the car has around 180k miles on it. The other thing I thought of was the suspenion im pretty sure its shot the car has had generic coilovers with stock struts for about a year and a half now. I can hear a similar noise when going over bumps but I dont thnk its the same noise...
Old Jun 20, 2006 | 04:55 PM
old man neri's Avatar
You could try to shake the wheel around and see if it has any play.
Old Sep 8, 2006 | 05:06 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: Wheel Bearings (old man neri)
i def have a wheel beaing issue. how long can drive on it till it GOES!!!
Old Sep 8, 2006 | 08:47 PM
Default Re: Wheel Bearings (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">i def have a wheel beaing issue. how long can drive on it till it GOES!!!</TD></TR></TABLE>
You don't want to find out. It could result in you losing some control of your vehicle on the highway as your wheel tries to seperate from the rest of your car.
Old Sep 9, 2006 | 05:40 AM
BLUE EH3's Avatar
Help we my pennies
it doesnt make a loud a sound!
Old Sep 21, 2006 | 04:48 PM
BLUE EH3's Avatar
Help we my pennies
bump
mouab18c1
Aug 2, 2014 12:21 AM
mulletmobile
Honda Civic (2001 - 2005)
Mar 5, 2013 12:05 PM
dc4teg95
May 2, 2010 08:08 PM
JDMhatchback20
May 6, 2007 06:40 PM
canooten
13
Dec 7, 2006 05:06 AM
