bov probs i think
Old Apr 16, 2002 | 09:33 PM
Pro-Lude's Avatar
Default bov probs i think
ok hes the deal i had the hks that comes with the fmax kit, well i wanted a louder one so i got the blitz. Well it sounds the same, sounds like a flutter and a sneeze. Is the something ive done wrong? any suggestions? TIA
Old Apr 16, 2002 | 10:23 PM
SlowB16's Avatar
Default Re: bov probs i think (Pro-Lude)
How many lbs are you boosting? At lower boost levels the Blitz flutters a bit.
Old Apr 16, 2002 | 11:23 PM
Flamenco-T's Avatar
use a different vacuum source....I had it happened before, then I move the Tee as close as I can to the vacuum source..it works like a charm
Old Apr 17, 2002 | 08:31 PM
Pro-Lude's Avatar
Default Re: bov probs i think (Flamenco-T)
Where would be the best plase to tie it in?
Old Apr 17, 2002 | 08:53 PM
SlowB16's Avatar
Maybe I should try that as well. worth a shot
kpxgq's Avatar
haha for some reason i read the topic as "boy problems"
Old Apr 17, 2002 | 09:22 PM
Etylorcen's Avatar
Default Re: bov probs i think (kpxgq)
LOL!
Old Apr 17, 2002 | 10:00 PM
Flamenco-T's Avatar
try to do it closer to the intake manifold and with less vaccum output
Old Apr 17, 2002 | 10:55 PM
Pro-Lude's Avatar
Sorry if this sounds stupid but what ya mean with less vaccum output
Old Apr 17, 2002 | 10:58 PM
Flamenco-T's Avatar
I tried not to tee more than 3 vacuum output out of a single source, for example, I tried not to put boost gauge, WG, FMU, BOV, and etc in one single source..
I had fmu, WG, and EBC from the FPR
then I had Boost gauge, EBC vacuum source(AVC-R), BOV on the evap purge
and I tried to tee it off as close as I can to the inake manifodl
Old Apr 17, 2002 | 10:59 PM
Pritos's Avatar
New User
less vacuum input.... meaning dont share the vac line with anything else except what was there originally and the bov. Hmmmm like find a vac line, T it, and the only thing u connect is for use with the bov ONLY. lots of em behind the intake manifold.
Old Apr 17, 2002 | 11:02 PM
Pritos's Avatar
New User
Default Re: bov probs i think (Pritos)
oh and trim all your vac lines to the MINIMUM length. no loose lines.
Old Apr 17, 2002 | 11:04 PM
SlowB16's Avatar
I have all three of my vac lines coming from one source, matter of fact all 4. fpr, WG, BOV, and FMU...it is working ok for the time being. But you say there are more behind the intake mani? I swear I looked and didnt see any....oh well worth another shot
Old Apr 17, 2002 | 11:09 PM
Flamenco-T's Avatar
Default Re: bov probs i think (SlowB16)
on your hood there;s a vacuum diagram from the factory , just folow it and yeah, no loose lines. keep it short
Pritos's Avatar
New User
I'm a sohc'er though. It may be different for your application. I use one in the back of my manifold strictly for the bov.
Old Apr 22, 2002 | 10:55 PM
Pro-Lude's Avatar
one for the wastegate? i dont have one for that, but i have a manual boost controller is that the reason?thanks
Dave.HR
Oct 29, 2010 05:32 AM
redsikiller
Oct 28, 2005 07:21 PM
TEG777
Sep 11, 2005 01:20 PM
M-EJ1
Jul 12, 2005 08:02 PM
ludelvr
Apr 30, 2002 12:44 PM
