broken bolt hole. What to do?
Old Jun 18, 2006 | 11:28 PM
SiMateoAko's Avatar
Default broken bolt hole. What to do?
After wasting all day on stupid mistakes with my engine swap, I am finishing up and I notice my valve cover bolt keeps spinning.
Yep. You guessed it. Busted.
I've included a zoomed-in version on the left of the image.
Can anyone recommend what to do about this hole? I would use epoxy or something (as I have the piece that broke off as well) but I'm afraid it will fall off again and screw with my rocker arms. Will it hold okay with just the four bolts?
Old Jun 18, 2006 | 11:53 PM
iphatcrxi's Avatar
Default Re: broken bolt hole. What to do? (SiMateoAko)
yeah its just a valve cover all it does it keep the oil from going everywhere
Old Jun 19, 2006 | 03:55 AM
mrtoastyjr's Avatar
if you have some down time i would probably give jb weld a shot. if you still have the other piece. that **** works wonders, just make sure that you get all the oil off with brake clean before starting and let it set a goog long time.
Old Jun 19, 2006 | 04:09 AM
ludesrv's Avatar
You can try JB weld. But if that doesn't work you will need to replace that peice. Any other head, judging by the forward facing spark plug holes, and the fast that your signature is gassavers.org, I'm assuming that's a D15Z1 head. Grab any other head from an OBD1 D series with SOHC VTEC and replace that peice. Better off the replace it then to rig it.
Old Jun 19, 2006 | 04:33 AM
mahatma's Avatar
Default Re: broken bolt hole. What to do? (iphatcrxi)
You can't just swap cam caps ***** nilly. You have to rig that one to work.
Old Jun 19, 2006 | 06:12 AM
SVOboy's Avatar
Aww, poor matt and his z1.
Old Jun 19, 2006 | 09:11 AM
SiMateoAko's Avatar
Default Re: broken bolt hole. What to do? (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">You can't just swap cam caps ***** nilly. You have to rig that one to work.</TD></TR></TABLE>
I have no plan on doing this. I think it's a silly idea actually. I'd rather just replace the entire head, and I have NO intention of doing that either.
Why would I replace the head on an engine with less than 60k on it?
I'm going to leave it as is for now. If I notice oil coming out the front area I'm going to have to try to JB weld it and tap a new hole. Maybe I should do that anyway considering that the engine won't be fired up for a few days.
Old Jun 19, 2006 | 09:16 AM
ludesrv's Avatar
Better yet, simply overtorque the valvecover by a few pounds. Before that, JB weld the hole in the VC shut haha. Problemed solved.
PS: Oil looks dirty, time to change it .
Old Jun 19, 2006 | 09:21 AM
killa rex's Avatar
i would take it to a welding shop that does aluminium welding..have them weld the piece back on or weld the whole thing and tap it again..IMO.
Old Jun 19, 2006 | 09:26 AM
SiMateoAko's Avatar
Default Re: broken bolt hole. What to do? (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">Better yet, simply overtorque the valvecover by a few pounds. Before that, JB weld the hole in the VC shut haha. Problemed solved.
PS: Oil looks dirty, time to change it .</TD></TR></TABLE>
Oil is from Japan compared to my old d15b2 that i just pulled, this is the cleanest oil in the world.
Oh, and I'm now scared to overtorque anything. Overtorquing the valve cover is what got me where I am now.
p.bass
14
Jun 30, 2014 08:28 PM
Animefun
Oct 28, 2012 08:55 PM
david420
Dec 30, 2011 09:56 AM
ramos2589
Feb 13, 2008 11:50 AM
methos713
15
Feb 18, 2005 12:13 AM
