Broken VC Bolt
Old 12-30-2011, 09:09 AM
david420's Avatar
Default Broken VC Bolt
Hey guys, recently i broke a vc bolt by over tightening it. The bolt is not even flush it broke off beneath the hole. Im pretty sure the only way to get it out would be with a drill extractor but i dont want shards of metal to go in my oil. Do i need to take the head off? Or can i keep driving with 4/5 vc bolts. So far it hasnt been leaking. thanks in advance
Old 12-30-2011, 09:14 AM
kaiba's Avatar
Default Re: Broken VC Bolt
Put rag towel around where you're going to extract. Drill small hole then use extractor tool.
Old 12-30-2011, 09:15 AM
EK9
Dc4LsTeG's Avatar
You need to pull the valve cover off and see if you can get the stud out with vise grips or something then replace the stud
Old 12-30-2011, 09:31 AM
david420's Avatar
I was thinking about doing something like that but wasnt sure if it was a good idea or not. Do you know of anyone whos done this?
Old 12-30-2011, 09:32 AM
kaiba's Avatar
It's the only right way. Go watch some youtube video.
Old 12-30-2011, 09:35 AM
david420's Avatar
I have taken the valve cover off and there is no way to grip it, The stud is under where it screws into. it broke off under, it is not even flush. my friend said i would have to take it to a machinist but i really dont want to.
Old 12-30-2011, 09:37 AM
david420's Avatar
ok thanks alot i will. I just wanted to know whether its worth it to take the head off or not but i would much rather do it this way seems way easier.
Old 12-30-2011, 09:43 AM
kaiba's Avatar
Use a center punch. It'll make the first drill easier.
Old 12-30-2011, 09:56 AM
david420's Avatar
ok thanks for the help
Potential2nr
01-17-2012 03:47 PM
deebo's ek9
10
09-30-2010 10:01 PM
murmur9
03-10-2006 05:06 PM
jadugartir
05-23-2005 10:44 AM
methos713
15
02-18-2005 12:13 AM
Quick Reply: Broken VC Bolt
