Strange cel problem
Old Jun 18, 2006 | 10:24 PM
preludeguy_92's Avatar
Default Strange cel problem
So the other day I pulled my engine to replace my transmission, when I got done and drove the car I got a check engine light. It does not come on until I hit operating temerature. This is where it gets bizzare. I was letting the car idle and while I sat there the temp gauge rose above normal but the fans did not kick on, so I shut the car off and then the fans kicked on. Are these problems related. I also tried bridging the service connector it threw no code. Wtf is my cars problem?
Also:The car runs fine seems to not be in limp mode or anything
Old Jun 18, 2006 | 10:31 PM
Hawkze_2.3's Avatar
Default Re: Strange cel problem (preludeguy_92)
Wierd..I'd disconnect the battery for 30 sec to reset the ECU and see if the CEL pops up again. If it does and you jump the connector and still don't get a code, you could have a bad ECU or something...
Old Jun 18, 2006 | 10:57 PM
98vtec's Avatar
moderator emeritus
Default Re: Strange cel problem (Hawkze_2.3)
very weird. Check all of your fuses. To me, this sounds like an electrical problem. and probably a very simple one since its not effecting the motor.
Old Jun 18, 2006 | 11:10 PM
Default Re: Strange cel problem (98vtec)
Already reset the ecu still getting the cel... with *no success on the code
Modified by preludeguy_92 at 9:59 PM 6/19/2006
Old Jun 19, 2006 | 03:48 AM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
whats the code??? did you replug the speed sensor in??? wierd sounds like you forgot to plug something in
Old Jun 19, 2006 | 09:01 PM
Default Re: Strange cel problem (I got the CD5 Jeebies!)
i cant find where i forgot to plug anything in.
Old Jun 19, 2006 | 11:14 PM
whats the code???
Old Jun 21, 2006 | 11:23 PM
i miss typed, no code as per the edit
Old Jun 22, 2006 | 08:50 AM
so whats it doing now if anything???
skaternak
12
Aug 13, 2009 08:39 PM
freshvibes
Feb 27, 2009 09:45 PM
ls19integra95
Feb 26, 2008 07:16 PM
drumking15
Feb 14, 2007 07:44 PM
