ViS CF TRUNK + rear Trunk Shocks Work??
Old Jun 17, 2006 | 04:43 PM
J.nguyen's Avatar
Default ViS CF TRUNK + rear Trunk Shocks Work??
does a ViS CF TRUNK be adaptable /w the OEM rear trunk Shocks?? i have no rear trunk shocks so i have to hold it up with my hand always, wanna buy some oem ones. wondering if they can be installed correctly w/o any complications.
Old Jun 17, 2006 | 09:07 PM
J.nguyen's Avatar
Default Re: ViS CF TRUNK + rear Trunk Shocks Work?? (JesDM)
Old Jun 17, 2006 | 09:12 PM
lsvtek's Avatar
yes it should work
Old Jun 18, 2006 | 06:51 PM
J.nguyen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drlsintegra &raquo;</TD></TR><TR><TD CLASS="quote">yes it should work</TD></TR></TABLE>\
can i get a 2nd.. pleease
Old Jun 18, 2006 | 06:53 PM
__oversea's Avatar
waste of money
yes it will work. if no, just drill it. thats it
Old Jun 19, 2006 | 09:38 AM
yee SERIOUS's Avatar
my friend's cf trunk doesn't allow for the shock towers. but i think his trunk is a seibon....
Old Jun 19, 2006 | 09:46 AM
boostnhoe's Avatar
Default Re: ViS CF TRUNK + rear Trunk Shocks Work?? (Last For One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Last For One &raquo;</TD></TR><TR><TD CLASS="quote">waste of money
yes it will work. if no, just drill it. thats it</TD></TR></TABLE>
You must be poor... If they dont work drill it ?? OK ?? Yes the shocks work fine on my VIS Integra carbon fiber trunk,No mods needed ....
Old Jun 19, 2006 | 02:14 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: ViS CF TRUNK + rear Trunk Shocks Work?? (boostnhoe)
I think VIS advises against using the stock lifters....the lifters are too strong and it can crack your trunk.
Old Jun 19, 2006 | 03:29 PM
Uncle Willie's Avatar
Default Re: ViS CF TRUNK + rear Trunk Shocks Work?? (carma_626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carma_626 &raquo;</TD></TR><TR><TD CLASS="quote">I think VIS advises against using the stock lifters....the lifters are too strong and it can crack your trunk. </TD></TR></TABLE>
QFT. Dont put them on, they will most likely crack the "carbon fiber". Just keep a prop rod in ur trunk. Not worth crackin the hatch.
Old Jun 19, 2006 | 07:33 PM
J.nguyen's Avatar
Default Re: ViS CF TRUNK + rear Trunk Shocks Work?? (RIP Indian Larry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIP Indian Larry &raquo;</TD></TR><TR><TD CLASS="quote">
QFT. Dont put them on, they will most likely crack the "carbon fiber". Just keep a prop rod in ur trunk. Not worth crackin the hatch.</TD></TR></TABLE>
ic.. thanks for tellin me in time. was bout 2 buy some.. where can i get a prop rod?
Old Jun 19, 2006 | 07:40 PM
Just use a stick of wood or somthing. You can buy them through service champ, but it will probably be expensive.
Old Jun 19, 2006 | 09:08 PM
mike9571's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIP Indian Larry &raquo;</TD></TR><TR><TD CLASS="quote">Just use a stick of wood or somthing. You can buy them through service champ, but it will probably be expensive.</TD></TR></TABLE>
Just steal your moms broomstick handle...and cut it to whatever size
Old Jun 19, 2006 | 10:02 PM
boostnhoe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carma_626 &raquo;</TD></TR><TR><TD CLASS="quote">I think VIS advises against using the stock lifters....the lifters are too strong and it can crack your trunk. </TD></TR></TABLE> I drive my car with a VIS carbon fiber trunk every day and Open and close my trunk with No problems Its never cracked?? You have to close the trunk by holding both sides of the trunk and just push it down.... My trunk still looks new with no cracks ...
92integraVTECgsr
Dec 18, 2007 06:55 PM
ejmatzell
Nov 8, 2006 10:59 AM
GRANT!
Sep 26, 2006 11:34 AM
Civic138
Mar 15, 2005 05:17 AM
DCbb6
Oct 1, 2003 10:36 AM
