AC question
Just noticed that my AC is no longer working. Not quite sure when this happened but it was recent, when I press the button on the console it still lights up and says that the AC is on, but the compressor isn't kicking on. Not sure if there are any fuses that I can check or if there are any tests I can do so any help would be appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">If the freon is to low, the compressor will not kick on. So I would say there is a leak.</TD></TR></TABLE>
x2
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_RaceR »</TD></TR><TR><TD CLASS="quote">or maybe just need a recharge.
Freon does not run out like gasoline, its in the system for ever. If its low, its low for a reason.
Freon does not run out like gasoline, its in the system for ever. If its low, its low for a reason.</TD></TR></TABLE>
x3
x3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M15 »</TD></TR><TR><TD CLASS="quote">I'll swing by autozone and get some of that R-134 and see if that is what it is. . .if it is a Relay how do I test that?</TD></TR></TABLE>
unless your car has been converted, it doesn't use r134a, it takes r12 which you need a license to buy... but you can buy the conversion kit to convert to r134a for like 30 bucks, but i dunno if you feel like spending that much for AC, plus when your purging the old r12 don't let anyone know or see you, its a federal crime
slow99gsr
Jul 16, 2006 03:04 PM
crazy eyez killa
Nov 30, 2004 09:24 AM
