denso oil cooler
Old Jun 17, 2006 | 10:20 AM
nonvteclude's Avatar
Default denso oil cooler
ok i have a 95 h23, i just resently had to by a new radiator and it was a denso oil cooler. i have looked alittle bit but not much havent really had time to look more in depth, but does anyone knoe where i would run the oil lines from to use this oil cooler
Old Jun 17, 2006 | 11:12 AM
DIRTYsouthBB6's Avatar
The easiest way is to just use an oil filter sandwich adapter and run the lines from it to the radiator and then back to it.
Old Jun 17, 2006 | 06:00 PM
Hawkze_2.3's Avatar
Default Re: denso oil cooler (nonvtechlude)
That's for an automatic tranny to cool the fluid, but if you don't mind more places for oil to leak on your car, then just just get a sandwich adaptor like /\/\he said.
Old Jun 17, 2006 | 09:09 PM
Default Re: denso oil cooler (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">That's for an automatic tranny to cool the fluid, but if you don't mind more places for oil to leak on your car, then just just get a sandwich adaptor like /\/\he said.</TD></TR></TABLE>
I understand that adding external oil lines would increase the chances of having an oil leak, but wouldn't the benefits of having an oil cooler greatly outweigh the risk of a small leak?
Old Jun 17, 2006 | 09:25 PM
Hawkze_2.3's Avatar
Default Re: denso oil cooler (DIRTYsouthBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRTYsouthBB6 &raquo;</TD></TR><TR><TD CLASS="quote">
I understand that adding external oil lines would increase the chances of having an oil leak, but wouldn't the benefits of having an oil cooler greatly outweigh the risk of a small leak?</TD></TR></TABLE>
I guess it really depends on whether or not you have problems with oil temp. A high hp turbo setup would benefit from an oil cooler a lot more than someone with just I/H/E...
Old Jun 17, 2006 | 09:44 PM
pos_cd5's Avatar
I guess it really depends on whether or not you have problems with oil temp. A high hp turbo setup would benefit from an oil cooler a lot more than someone with just I/H/E...</TD></TR></TABLE>
Old Jun 17, 2006 | 09:50 PM
That's true... but seeing as how engine oil is the lifeblood of your engine, I've just always thought that it was a great idea to have an external oil cooler ( as long as the oil cooler has a thermostat to keep it from staying too cool )
Old Jun 17, 2006 | 10:38 PM
pos_cd5's Avatar
That's true... but seeing as how engine oil is the lifeblood of your engine, I've just always thought that it was a great idea to have an external oil cooler ( as long as the oil cooler has a thermostat to keep it from staying too cool )</TD></TR></TABLE>
go for it, and you live in texas too. it definately wont hurt in the texas summer heat
Old Jun 18, 2006 | 12:48 AM
Rosko's Avatar
Default Re: denso oil cooler (pos_cd5)
I dont know about the radiator you've got but the tranny cooler lines I've seen on V8's really arent that big and I doubt that it would flow enough oil.
The passage from the oil pump to the filter is pretty big and you're basically gonna choke it down by running it through that cooler before it gets to you're filter.
Like I said I havent seen youre radiator, but its just something to think about.
Old Jun 18, 2006 | 09:56 PM
thanks for the input guys, wasnt relly sure if i was going to do it. but becuase i have the option i would like to do it. but from what i hear it will leak, and i just fought my car for a year to stop oil leaks so i doubt ill do it. thanks again
rcbusiness
Honda Civic (2001 - 2005)
Jul 13, 2017 01:50 PM
dumkopf
Nov 13, 2007 08:58 PM
Bense
19
May 19, 2006 05:44 PM
realblag
Aug 26, 2003 06:48 PM
Backmarker
Jan 14, 2003 02:19 PM
