Turbo Timer Install Help?
Old Jun 17, 2006 | 07:28 AM
HamiltonRex's Avatar
Default Turbo Timer Install Help?
Hi,
Under the dash.. I have 7 wires on the bottom of the ign key..
3 go to 1 plug
4 go to another
3 Plug
white - 12v
white/blk - 12v
blue/white - ON
4 Plug
yellow - ON
white/red - ACC
blk/white - GND
blk/yel - ON
Now.. My greddy timer requires 12V,ON,ACC.
My question is.. Which wires should i use for the 12V and ON wires? There are more then 1.
Thanks.
Old Jun 17, 2006 | 09:30 AM
Metal Typhoon's Avatar
Default Re: Turbo Timer Install Help? (HamiltonRex)
any of them should work...
Old Jun 17, 2006 | 09:31 AM
well..
Since no one knows. I just picked out a few hooked it up. She no work.. It keeps my radio on though hahah lol..
ANy ideas whats wrong here?
Old Jun 18, 2006 | 12:45 PM
Help!
I think i may have it on the wrong ON wire.. Since its giving power to all my accessories.. radio/heater/etc etc.. But not anything in the 2nd position of the key..
I may try and move the ON wire around see if i can get it to keep the car running instead of just all my accessories.
Old Jun 18, 2006 | 01:56 PM
Autoworks's Avatar
-red on timer to solid white wire on ignition
-blue on timer to solid yellow wire on ignition
-green on timer to black & yellow wire on ignition
-black on timer to ground
Old Jun 19, 2006 | 08:07 PM
Default Re: Turbo Timer Install Help? (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">-red on timer to solid white wire on ignition
-black on timer to ground</TD></TR></TABLE>
Thats i will try this.
So your basically saying, instead of hooking up the wires to, 12V, On, and ACC. Hook up to 12V and 2 ON's?
Old Jul 27, 2006 | 02:58 PM
Ch3mik's Avatar
Default Re: Turbo Timer Install Help? (Ch3mik)
Old Jul 28, 2006 | 01:24 PM
Ch3mik's Avatar
anyone? i tried these instructions and it doesnt keep my car on.
Old Aug 8, 2006 | 09:02 AM
Ch3mik's Avatar
anyone ?
heres a pic of my ignition wires. Its a 1990 crx HF. also , would an alarm interfere with its function?
I currently have it hooked up like this:
-red on timer to wht/red
-blue on timer to yel
Autoworks recommended:
the only wire that doesnt go is the red to the wht/red. should i try the red wire from the greddy harness to the blk/wht?
I just re read the thread. am i supposed to be messing with wires from TWO plugs? or just the one in my pic?
Old Aug 8, 2006 | 05:03 PM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ch3mik &raquo;</TD></TR><TR><TD CLASS="quote">anyone ?
I doubled checked myself. The red does go to the solid white, so the wires I have are correct. Have you traced the wires up to the ignition key switch?
Old Aug 8, 2006 | 05:08 PM
92integra_gs's Avatar
bookmarked
Old Aug 9, 2006 | 02:10 PM
Ch3mik's Avatar
so I take it i need to take apart my steering column cover? cuz I see no solid white wire anywhere near the fusebox.
Old Aug 9, 2006 | 03:22 PM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ch3mik &raquo;</TD></TR><TR><TD CLASS="quote">so I take it i need to take apart my steering column cover? cuz I see no solid white wire anywhere near the fusebox. </TD></TR></TABLE>
Yes
Old Aug 9, 2006 | 05:03 PM
Ch3mik's Avatar
got it runnin. no one mentioned a THICK white wire and that it was coming DIRECTLY off the ignition. lol. also, that white thick one turns into a thick wht/blk when it comes to the fuse box . I was working off the wires from the fuse box
Old Aug 9, 2006 | 06:07 PM
Autoworks's Avatar
the1337aaron
14
Oct 12, 2010 06:16 AM
denshu
Lighting
Nov 8, 2007 08:02 AM
PINKS
Mar 13, 2006 02:46 PM
acuragtr
Aug 8, 2004 04:47 PM
Flamenco-T
Nov 6, 2001 06:54 AM
