welding sheetmetal
Old Jun 17, 2006 | 05:46 AM
Hkustoms's Avatar
Default welding sheetmetal
I've got a 2000 cx hatch with strong b20 with act extreme, hasport mounts, Itr tranny oem lsd, and run R compound tires. on the street it launches ok with wheel spin/ slight hop.
The passanger side fender well is starting to rip, let me make this more clear, RIP!
I'll be pulling the motor/ trans out next month to change cams, pumps, belt/tensioner, pulley, rod bolts, bearings, and pan/ lower gaskets. It's just easier for me to work on outside of the bay.
While motor is out I'm planning on getting sheetmetal rewelded, holes filled and clean up wiring of harness and accessories. my main ? is when I look into getting someone to help weld up the fender/holes what type of machine should I be getting someone to use as well as procedures?
thanks for your input, and in no way am I saying my 200hp beseries is causing the rip but lately it's not helping and I'm usually not one for letting a mustang roll by without giving them some hassle, but recently I've had to refrain.
Rob
Old Jun 17, 2006 | 06:10 AM
DaveF's Avatar
Default Re: welding sheetmetal (Hkustoms)
just use a normal mig welder, but before you do, be sure to take a wire wheel to all the undercoating/seam sealer/paint...... if you dont it will make the weld contaminated, and also catch on fire, put off some nasty fumes......
Old Jun 17, 2006 | 06:41 AM
ManBearPig4silly's Avatar
Got pics of the rip?
I hate to say it but.........
Maybe 90blackcrx's fender braces are in order?
Old Jun 17, 2006 | 09:29 AM
RCautoworks's Avatar
Default Re: (I4sillypwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I4sillypwr &raquo;</TD></TR><TR><TD CLASS="quote">Got pics of the rip?
Maybe 90blackcrx's fender braces are in order?</TD></TR></TABLE>
I no longer make them for the crx, but I have gotten so much interest for other chassis that it has crossed my mind.
Thanks silly, even though you hate to say it
Maybe this will give the guy some ideas
Old Jun 17, 2006 | 10:48 AM
ophdehEEEzy's Avatar
Default Re: (90blackcrx)
What exactly does that 'fender brace' do?
Old Jun 17, 2006 | 10:58 AM
Default Re: (OH ISH ITS DAT FOOL JAMES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OH ISH ITS DAT FOOL JAMES &raquo;</TD></TR><TR><TD CLASS="quote">What exactly does that 'fender brace' do?</TD></TR></TABLE>
Stiffens the front end, before anyone ask, no I have not had any scientific test done, the test would of out weighed the price of the braces. I have had a couple people get back to me with comments found here.
http://www.rcautoworks.com/FenderBracecomment.htm
I loved them, I original made them for my car but others wanted a pair, that's how it started. I would not of spent my money on something that did not work.
Old Jun 17, 2006 | 11:04 AM
Since you are considering welding the fenderwell anyway you could just weld up something like in that picture to brace it.
Old Jun 19, 2006 | 10:48 AM
CBURKE's Avatar
A good way to check them out would be to jack up the front of the car and put the jack stands where they go, when you remove the jack the car should not flex as much. I think thats about right.
shaggsdb
21
Jan 8, 2009 03:28 PM
whiteciv88
Jun 26, 2008 06:37 PM
MY_EF_NINE
Jun 5, 2007 10:56 PM
See Are X
Aug 3, 2006 12:14 PM
blaketion
Jun 6, 2005 07:57 PM
