B16 throwin out black smoke only when warm???
Old Jun 16, 2006 | 06:28 PM
90jdmcrxdude's Avatar
Default B16 throwin out black smoke only when warm???
I have a B16a swap in my 90 crx dx and it runs great when its cold, however once it gets warmed up it begins to run like crap. It boggs down when I hit the gas, and it blows out black smoke from the exhause and theres a coating of unburned fuel on the back of my car. The warmer the car gets the worse it gets. It doesnt overheat or anything it just runs real bad. I am throwing a code for knock sensor and I have checked it a few times and there seems to be nothing wrong with it... plus it wouldnt make my car run this bad. Once the car is warmed up and I stop driving, or shut the car off... then go to hit the gas or start the car it gets really bad. I can push the gas all the way to the floor and all it does is rev at a constant speed for a little while and then all of a sudden like something starts to work it revs right up. But once it goes back down in rpms the car is really hard to get the rpms back up. I was getting 6mpg then for a while I started to get like 12-15 and now I think its back down to 6mpg. I have started to put lucas injector cleaner in, because I have heard that, that is a good product. I felt a difference the first time I put it in, but the second time it started to act bad again. I have 2 ecus and they both do the same thing everything is hooked up properly so I dont know what the problem could be. Does anybody have an idea?
Old Jun 16, 2006 | 06:32 PM
SiR Inspired ED7's Avatar
Default Re: B16 throwin out black smoke only when warm??? (90jdmcrxdude)
have you made sure your Vac Lines are on where they should be?
o2 sensors good?
Old Jun 16, 2006 | 06:34 PM
Default Re: B16 throwin out black smoke only when warm??? (SiR Inspired ED7)
I have brought it to different shops and they have changed to O2 sensors and checked the vacuum lines so they are all good.
Old Jun 16, 2006 | 06:38 PM
Do a Compression Check, or a leak down check
Old Jun 18, 2006 | 03:51 PM
I did a compression check and its like 210 across how can I do a leakdown check? I know this a dumb question, but is it something I can just do or do I have to bring it somewhere?
Old Jun 18, 2006 | 03:59 PM
nappyroots827's Avatar
good chance its your coolant temp sensor...This adds more fuel when the car is cold to compensate for the denser cold air, and when the coolant warms up, this tells your ecu to cut back on the fuel...So if these go bad, you'll run rich as donald trump, which it sounds like ure doin
Old Jun 18, 2006 | 04:02 PM
Default Re: B16 throwin out black smoke only when warm??? (nappyroots827)
Wouldnt it be throwing a code for that though, the only code I'm throwin is for my knock sensor
Old Jun 18, 2006 | 04:05 PM
crxnj's Avatar
why dont you fix the code for knock sensor ? why do people insist on driving the car with while the ecu is throwing codes?
Old Jun 18, 2006 | 04:07 PM
Default Re: B16 throwin out black smoke only when warm??? (Mr.speaker)
I have tried to fix it, but everybody says that the knock sensor is a plug with only one wire... mine has 2 and I'm positive that its the knock sensor, because all of the pics of them on the internet show where it is, and the plug I have there has 2 wires out of it, I have been trying to fix that for about 6 months now and am still dumbfounded
Old Jun 18, 2006 | 04:10 PM
crxnj's Avatar
how have you tried to fix it? replacing it? rewire? checking at the ecu clips? reset the ecu?
Old Jun 18, 2006 | 04:11 PM
all of the above except replace, do you know how much they cost?
Old Jun 18, 2006 | 04:14 PM
crxnj's Avatar
well if you get it from honda im sure it will be alot....but check ebay sometimes they have them..
Old Jun 18, 2006 | 04:31 PM
crx_88_si's Avatar
i think the ecu refuses to do vtec w/ the knock code. so that might have something to do with it.
also, are u using 91oct?
Old Jun 18, 2006 | 04:40 PM
Default Re: (crx_88_si)
no I'm using 89 and I'm hitting vtec
Old Jun 18, 2006 | 05:43 PM
Default Re: (90jdmcrxdude)
it wont necissarily throw a code for the coolant temp sensor, because it may already be running in limp mode cuz of the knock sensor code, so a combination of the coolant temp sensor and the limp mode, that could be your promblem, just a thought
Old Jun 18, 2006 | 05:46 PM
Default Re: (nappyroots827)
so how could I tell if the coolant temp sensor is no good?
Old Jun 18, 2006 | 05:57 PM
bwilly's Avatar
I have the same motor and yr car but mine is an si im throwing the knock sensor code and its doing the same thing but I have yet to find a knock sensor to replace it with exept at honda they are asking $180 and any shop ive went to is dumfounded also. get back at me if you find a fix
Old Jun 18, 2006 | 05:58 PM
i dunno if there is a specific resistance between the two terminals a certain temps, im sure there is but i dont know em off the top of my head, or you could just replace it anyways, there like 18 bucks or sumthin
I guess you could pull it out, check the resistance, then get some hot water, put it in the hot water for a min. pull it out and check it, see if the resistance changed, that would be the ghetto way, haha
Old Jun 18, 2006 | 06:09 PM
Well I just bought a new vtec subharness to try to fix the problem possibly. I'll let you know how it goes.
Old Jun 18, 2006 | 06:42 PM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nappyroots827 &raquo;</TD></TR><TR><TD CLASS="quote">i dunno if there is a specific resistance between the two terminals a certain temps, im sure there is but i dont know em off the top of my head, or you could just replace it anyways, there like 18 bucks or sumthin
I guess you could pull it out, check the resistance, then get some hot water, put it in the hot water for a min. pull it out and check it, see if the resistance changed, that would be the ghetto way, haha</TD></TR></TABLE>
you have to check the resistance at certain temps. so u cannot pull it out to test. get a manual all the specs are in there. a 88-91 EF manual will work cuz the sensors are the same electrically.
Old Jun 18, 2006 | 08:06 PM
crxnj's Avatar
http://www.rockauto.com/catalo...,2483
http://search.ebay.com/honda-k...srtZd
Old Oct 14, 2006 | 05:14 PM
standinghollow's Avatar
Old Oct 14, 2006 | 08:19 PM
Bob_760's Avatar
Default Re: B16 throwin out black smoke only when warm??? (standinghollow)
Just wanna say I'd be shocked if its the knock sensor, when i got my car it had no O2s, IAT, IAC, or Knock sensor and it ran "fine" hit vtec and everything. I've since rid myself of all the CELs and the only thing that made a noticable difference was the IAT. Would i reccomend you get a knock sensor? Yes. Do I think that will help you? Unless it has something to do with the fact that I was running 93 and you're running 87 no.
It sounds more like the coolant sensor also its rare that a coolant sensor trips a CEL due to the fact that there is no out of range for the sensor... if its cold its one way if its hot its the other if it breaks it just thinks its whatever temp its at all the time, the ECU dosen't have any information to believe otherwise.
Juan_Mitosis
17
Jul 16, 2008 02:41 PM
Soccerking3000
Aug 21, 2006 04:05 PM
90jdmcrxdude
13
Jun 19, 2006 04:47 AM
geminis2k
Nov 10, 2003 01:14 PM
B00ST2nR
Mar 2, 2003 10:44 PM
