Is a lower arm bar the same thing as a lower tie bar???
Old Jun 16, 2006 | 04:06 PM
T
Default Is a lower arm bar the same thing as a lower tie bar???
First off I posted already in the suspension forum I just figured i would get a quicker response here than there. Hey I was just wondering is a lower arm bar the same thing as a lower tie bar but in different wording, im asking this because i was told they are the same part. But i have some uneasiness about that answer cuz both parts sort of look differently than each other and i dont want to waste my money buying wrong parts.
The two parts in question is the DC Sports Lower Rear Tie Bar and the Skunk2 Rear lower arm bar.
Here's a link to both parts to get a better idea.
http://www.robearracing.com/ca...1.cfm
I plan on buying either the DC or Skunk2 lower tie bar and some Omni Power LCA's for my DA and i want to be sure.
Also is there an advantage in buying an aftermarket front crossmember??
Old Jun 16, 2006 | 04:23 PM
Mt3c's Avatar
25 Year Member
Default Re: Is a lower arm bar the same thing as a lower tie bar??? (T"u"Rtle)
they go in the same place.
Old Jun 16, 2006 | 04:25 PM
T
Default Re: Is a lower arm bar the same thing as a lower tie bar??? (Mt3c)
so it would be considered the same thing, no??? Is there an advantage either one has over the other one?? What i dont get is if its the same thing, goes in the same place, why dont both parts have the same name??? Is it just a companies preference thing on what to call parts and what not?? Or is their a technical reason??
Old Jun 16, 2006 | 04:28 PM
__oversea's Avatar
DC sports Tie bar = look, non-function
Skunk2 = better than DC. function.
Old Jun 16, 2006 | 04:29 PM
DC2_2's Avatar
Default Re: Is a lower arm bar the same thing as a lower tie bar??? (Last For One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Last For One &raquo;</TD></TR><TR><TD CLASS="quote">DC sports Tie bar = look, non-function
Skunk2 = better than DC. function.</TD></TR></TABLE>
took the words right outta my mouth!
Old Jun 16, 2006 | 04:31 PM
T
What do you base your opinion on??
alright then skunk2 it is thats the one i wanted anyways. So for my rear it is going to be Skunk2 Rear Lower Arm Bar complimenting Omni Power Rear Lower Control Arms.
Now Cusco offers a front lower tie bar and innovative mounts offers a aftermarket front crossmember, are there any advantages in buying these products as well??
Are there front lower control arms??
Old Jun 16, 2006 | 04:36 PM
00IntegrAllmotoR's Avatar
HT Black OPs
None = function if the mounting bracket isn't welded down.
Old Jun 16, 2006 | 04:37 PM
__oversea's Avatar
yes they sell from arm as well. but i dont see many people upgrading the front.
are you talking about front H-beam? it will help you from wheel hop. but i wouldnt recommand if your car is lowerd. because they hung low.
Old Jun 16, 2006 | 04:44 PM
T
thanks for all the replies guys and that makes perfect sense with the welding. Yeah i guess i just want to get all my suspension done. Next after the LCA's and Rear LTB is gonna be the front LTB and Crossmember and suspension bushings. Im getting all into suspension so i want to do it right i guess you could say.
Old Jun 16, 2006 | 04:46 PM
__oversea's Avatar
oh btw, if money isnt problem, why not function7 LCA instead of Omni?
Old Jun 16, 2006 | 04:49 PM
HT Black OPs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T"u"Rtle &raquo;</TD></TR><TR><TD CLASS="quote"> Im getting all into suspension so i want to do it right i guess you could say. </TD></TR></TABLE>
Thats the attitude to have
Do it all right the first time, is better then doing it twice.
Also I suggest not to get a front tie bar. This is my Spoon with a 1.5 inch drop.
Old Jun 16, 2006 | 04:50 PM
T
Default Re: Is a lower arm bar the same thing as a lower tie bar??? (00IntegrAllmotoR)
damn and my car is probably lower than that i sure as hell aint gonna get that bar then thanks for the info cuz i would never have thought of that.
Old Jun 16, 2006 | 04:51 PM
T
where can i get function7 LCA's at?? Whats so much better about these LCA's compared to Omni??
Old Jun 17, 2006 | 12:17 PM
HT Black OPs
I got SPC and I love them. Came with the holes for my ABS line and a bushing that goes between the LCA & sway bar endlink bracket. Since I got the ITR sway it helped out alot.
Old Aug 24, 2006 | 11:35 PM
bigstatik's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T"u"Rtle &raquo;</TD></TR><TR><TD CLASS="quote">where can i get function7 LCA's at?? Whats so much better about these LCA's compared to Omni??</TD></TR></TABLE>
well do you want the original? or the imitation made with cheaper materials?
https://honda-tech.com/zerothread?id=1726725
Old Aug 25, 2006 | 06:45 AM
DavidR's Avatar
Hmm, well, it is a pretty flattering gesture to have someone knock off your product, it says you know what you're doing...
You can get Function7 arms through me, if you wish.
Modified by DavidR at 7:02 PM 8/25/2006
00zzySi
14
Mar 5, 2010 04:51 PM
JMelt4
Suspension & Brakes
Mar 18, 2007 09:19 AM
T"u"Rtle
Suspension & Brakes
Jun 16, 2006 08:07 PM
sohcvtec1995
29
Apr 24, 2004 06:16 PM
Suave99
Sep 3, 2002 07:09 AM
