B series: shifting diagnosis
ok, i have a 90 CRX with a B18A1 and B16 trans (cable) which was recently purchased (the car that is).
basically the problem is it's hard to get into most gears and will grind in 4th, i am almost positive this is a synchro, slider, blocker ring, or even shift fork problem but i am wondering if it could be something simpler.
there isn't much play in the shifter all around, BUT i can yank up on it about a half an inch and hear the linkage bang underneath when i do it. could these tranny problems possibly be due to missing bushings or a linkage problem?
i would greatly appreciate responses as this is my daily driver! thanks
well i found out that the linkage by the bottom of the shift rod was not even bolted up! (the 2 bolts that hold in the bigger bushing to the bottom of the car) and that's why i was able to move it up and down, it was banging on the exhaust.
it is still pretty hard to get into gears though, i am going to try the GM Synchromesh Modified for the trans to see if it will make a difference, at least get rid of the 4th gear grind for now.
as for it being hard to get into gear, i am leaning towards trans issues, the linkage looks fine to me...unless i am not doing something right. i have a feeling one of the shift forks are bent, which i hope not.
any other suggestions guys?
btw: the bottom of the shift linkage says "race tech" don't know if it matters.
Try replacing the clutch slave cylinder. When I did my GS-R swap it would do the same problems you stated. I thought it was just a bad clutch,so I replaced it, still did the same thing (needed a new clutch anyway). So I replaced the clutch slave and pretty much fixed it. So try replacing it, if it doesnt work then you know its not the clutch slave, then just go from there.
blkcivic310
Jul 21, 2010 08:19 PM
