DSM 450CC injectors?
Hi, through the help of sgT I picked up some DSM 450cc injectors for 50 bucks, what else do I need with these to make then "plug and play" in my car for use with hondata?
You'll need:
*Seals and o-rings (new ones -4 each)
*spacers
*resistor box (off of an older Honda is OK)
*injector clips
*some wires
*electrical tape
*common sense
*spacers
*injector clips
*some wires
*electrical tape
*common sense
walk out to your car. (with one DSM injector in hand)
pop open hood.
unclip 1 electrical connector from stock injector.
try to insert clip and injector.
if no fit, you need DSM clip. if fit, you no need electrical connector.
if you're talking about spark plugs, then yes, you need spark plugs for your car to run.
D
pop open hood.
D
turbotime
May 14, 2006 02:33 PM
